Originally posted by BillysGruff
View Post
Announcement
Collapse
No announcement yet.
BlueOx build
Collapse
X
Originally posted by 93 Krawler View PostI used air soft pellets in my 39.5 TSL's and it didn't help. Death wobble was horrible, so I went full hydraulic steering. Problem solved.
Hey Gents, been a while. I got the tires all setup with PVC inserts from Andy @TWF, and got the air soft pellets from Wally World. It definitely doesnt shake as much
But then, I'm working on hydro-assist and its not working for me.
Drilled and tap'd the box
Getting brackets tack'd in place
Supposedly I had everything correct.
Faaacccckkkk. I'm trying to bleed the system and no fluid gets down to the ram. It doesnt move at all because of this. There isnt any fluid going to the 90° adapter. The only seal I had to replace was the one on the back end of the piston. It was a 'square' ring seal over top of a rubber o-ring. I did have some blockage coming in the pressure line so I blew it out with the air compressor. When I removed the pressure line the second time to check for problems, there wasnt any fluid dripping out of it, even though the resevoir had plenty. Anybody want to come help me diagnose, I'm stumped? I would provide beer.
Do the the tires move at all? If no, then you might have done something wrong putting it back together.
When I tried hydro assist on mine it didn't help. The angle of the drag link made it so it couldn't push very good. That's why I went to full hydro. My box was different than yours. I tapped it differently too.
Originally posted by 93 Krawler View PostDo the the tires move at all? If no, then you might have done something wrong putting it back together.
Originally posted by Ky Mudhunter View PostBased on your mockup in this pic I think you have the hoses switched on the ram. The box is trying to go left while the ram is trying to right.
Did you bleed the system? If not, jack the front end up. Then turn the wheels back and forth from lock to lock with the engine off. Keep checking the fluid level and keep it full. This may take a while because of the extra volume of the assist cylinder you need fill.
Make sure you go ahead and switch the hoses because it probably will not bleed the air out of the cylinder with them backwards.
If there is no fluid coming out of one of the ports you drilled and tapped on the steering box, then there is something wrong. Either the box has some internal issue or it was drilled in the wrong spot. Mine is drilled and tapped the same way showed by 93 Krawler but also a different style box. Just to clarify:
- If you jack the front wheels off the ground they won't turn side to side at all?
- Is this with the ram installed? If the hoses are backwards the ram is fighting the steering box. If the ram is not installed (just hanging) and the wheels won't turn then look at the box.
- If you disconnect the steering box from the pitman arm or drag link, can you turn it?
For bleeding I had to have the ram connected so when I turned the steering wheel it forced it in and out. Tried with it just hanging and it wouldn't bleed without forcing the cylinder to move some other way. I've also never had any luck bleeding mine (hydro assist and hydro boost) with the engine off. It will just burp fluid out the remote reservoir forever, or at least until my forearms can't take it anymore and it is never bled. I just fill up the reservoir, start the engine, and turn the wheels lock to lock once or twice. Refill the reservoir and do it over a couple times. Once the reservoir level stays fairly constant I will start it up and turn lock to lock many times. Oh, if hydro boost brakes you need to pump the brakes several times after you turn the motor off each time. There is an accumulator in the brake system (so you still have some power brakes if the engine dies) that you need to release the pressure in order to get it to bleed.
Originally posted by blazerbrad View Post- If you jack the front wheels off the ground they won't turn side to side at all?
2. Yeah, tried bleeding with everything connected, even started the motor and did lock-lock a bunch.
3. Steering box turns fine with everything connected and on jackstands. Its gotta be fluid flow not assisting.
I'm confused as to why theres no fluid going to the box. Its the first stop for fluid after the pump. Also, I think only the HD's got the hydro brakes.
Originally posted by blazerbrad View PostI just fill up the reservoir, start the engine, and turn the wheels lock to lock once or twice. Refill the reservoir and do it over a couple times. Once the reservoir level stays fairly constant I will start it up and turn lock to lock many times. Oh, if hydro boost brakes you need to pump the brakes several times after you turn the motor off each time. There is an accumulator in the brake system (so you still have some power brakes if the engine dies) that you need to release the pressure in order to get it to bleed.Last edited by BillysGruff; 11-26-2014, 09:27 AM.
Ok, I finally did it right. I bought some Loctite hydraulic sealant and wrapped the fittings about 10 times with tape. I was able to bleed and drive it around and it doesnt leak! I also bought the plastic line separators. I plan to make either a small tab or maybe even a small skid plate to protect the hydro lines. i also cranked on the pressure fitting at the pump because it was leaking, too.
Also just ordered a NP208/205/241 flange and seals to swap onto the 241. I went to Jacks down on Kellogg to look for one. He said I'd have to buy the whole tcase for $100. I said I dont need all that, he says $50 for the flange. The one from Ebay was $45 w/free shipping. Ill take that over getting dirty, cussing, bloody knuckles/fingers.
I'm gonna head down to Jacks today to see if he has any HD Dodges. I hear the front driveshafts are a 1350 CV and the flange mates up well with the 205/208/241 flanges. I plan to cut it to length and sleeve it/rosettes/plugs. I'll call Besslers too, they're my favorite.
Glad you got it all working. I really like your build. Don't see as many fullsize builds around here.
One question (and I'm not flaming you): how come you mounted the hydro assist cylinder below the tie rod? I have mine mounted behind the tie rod directly above the axle tube. I did this because it keeps the cylinder a little more protected and takes full advantage of the hi-steer. Based on the pictures it looks like you could have done the same but maybe there is something I can't see in your pics that would not allow mounting it like I did. Below are some pics of my setup for reference (1 of my initial CAD design and 2 of it finished).Last edited by Ky Mudhunter; 12-12-2014, 11:13 PM.
Ah yes, I see where you're coming from. That looks like a good setup to me. Thanks for the compliments. The only difference we have is that your DL is in front of the TR, whereas mine is behind the TR. Things might get crunchy if I bumped the pass side. This allowed me to not have to move the steering box forward. I get a decent turning radius. The other thing in the back of mind the whole time was that I didnt want the lines running up and around tubing. I wanted to keep everything ahead and out of the way of the TR and DL.
Question for you though...Did adding the panhard help much? I've got decent body roll, and hear that helps. I can see it even when I'm getting in it, and can see the reflection in the office building windows. These 52's are definitely flexy. Do you keep it connected while wheelin and dealin? I'm debating whether I want to add one or not. If you still have the CAD of brackets for it, could you tell me the specs that worked for you? My DL is about 7°, and yours looks to be about the same.Last edited by BillysGruff; 12-13-2014, 05:21 AM.
Ok. I thougt there might be a reason you mounted it like you did.
The panhard bar did not help with the body roll much but it did make the steering feel a lot tighter, especially on curvy roads where you are steering back and forth. I do take it off when wheelin' because it makes the suspension bind when it flexes.
Yes I still have the CAD files of my brackets. My draglink is at about 8 degrees and my axle is D44 so they may not fit perfectly on the D60. I think the only difference is that the axle bracket may need to be a little taller. Do you have any software to view CAD files? If so, what software is it?
