Announcement
Collapse
No announcement yet.
Rear radiator
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Rear radiator
    So I decided to move my radiator in the Jeegy to the rear. I spoke to Kevin the owner of Reddot while In Moab and he said this would make a huge difference in radiant heat for the engine bay.
    I started today and hope to finish tomorrow with the plumbing. I also ordered a Uview vacuum system for any radiator. This will test the system with vacuum and check for leaks or failed components and will fill the entire system via Vacuum as well. So if you need to use it IM me and we can work something out.
    I also started the stainless steel heat shield. The Kevlar I had made burnt thru. Tony Bogolo is going to fix it.
ID:	77383Click image for larger version
ID:	77384Click image for larger version
ID:	77385Click image for larger version
    sigpic
Working...
X
