-   -   Anyone done a 4.0 head swap on a 258 ?? (https://www.cincyoffroad.com/forumOLDVB3/showthread.php?t=7089)
sarge 06-14-2011 12:31 PM
Well I fell in to a free 258 complete that has a lot of work done to it soooooooo..... I'm taking off Friday to start pulling motors apart to swap my old 4.0 head onto my new 258 . Keeping the F.I. of course.
Been searching the net and found a few good articles but wanted to here from some one that has done it ( cough , cough.... GPER ! ) .
Which dist. do I use?
if I use the 4.0 Dist. do I have to change the gear?
will my serp. setup bolt to the 258?
Any help would be great , I have to get this thing going...... it's killing me seeing all the rigs running around .
GPER 06-14-2011 08:10 PM
Why yes, yes I have. The HO head, water jackets drilled, tapped plugged, milled, and valve job.
http://img.photobucket.com/albums/v2...f/DSCN1257.jpg
Crane torquer cam, Mopar Performance valve springs.
http://img.photobucket.com/albums/v2...f/DSCN1708.jpg
Clifford 4.0 intake for a carb, I am going to stick with a carb.
Block bored 0.040 over.
http://img.photobucket.com/albums/v2...f/DSCN1255.jpg
Stock 4.0 exhaust
http://img.photobucket.com/albums/v2...f/DSCN2104.jpg
I haven't put the distributor in yet, but I will use the 258 distributor with the Team Rush upgrade with the e core coil and the Summit CDI box.
I used the stock push rods, a Melling HO oil pump and when I retire is my plan to put the motor in. Or it might come sooner if the bigger carb and header( when I find the hearder) for the 258 that is in the Jeep doesn't do the job pulling the Polaris Ranger on longer trips.
sarge 06-20-2011 11:55 AM
Thanks , I got mine about 98% assembled , I used the 4.0 dist. and it seems like it's going to work. Hoping to drop it between the frame rails tonight . :thumbup:
GPER 07-04-2011 07:18 AM
Well, fill us in with detail.
fmlewis 07-04-2011 11:35 AM
If your looking for a serpetine belt setup from a `86 258 I have a set of parts.
It came from a 258 with the dummy a/c pulley bracket. The only item missing from setup is the alternator bracket but I had planned on leaving the alternator in the orginal location and not running the dummy a/c pulley bracket. Or if I could find a cheap serpetine clutch for my york I would run it complete with OBA then, but I haven't. Now its just taken up space.
If you are interested let me know.
Frank
sarge 07-04-2011 05:13 PM
on vacation , I will fill ya inn when I get back , It runs great and I got it in the creek twice before leaving.
