Old 01-22-2015, 07:33 AM   #1
ohiozj
rear ford 9" ready to bolt in ZJ
i am selling a ford big bearing 9" rear end out of my ZJ.
full width 78-79 year F150 big bearing
converted to chevy disc brakes
coil buckets and shock mounts for ZJ setup
4 link trussed and gusseted
Yukon 31 spline shafts
Detroit locker
4.56 Yukon geared
1350 pinion with HD pinion guard
1/4" thick rear armor cover (with drain plug)
breather on top of centersection
shaved 1"
5 on 5.5" ford bolt pattern.
1/4" link mounts (flush with axle housing)
the only bad things are:
will most likely need a new pinion seal, it leaks a little gear oil from the pinion
the ends of the housing leak gear oil a little too
complete and ready to roll
1000.00
ohiozj is offline   Reply With Quote
