Old 08-10-2016, 11:56 AM   #1
Rush September 2nd -4th
Time to get back out to with Core at Rush Offroad and beat on your junk for the last time for 2016.
I currently have a few repairs that have to made in order to make this trip, it would take a miracle to get everything complete in time with my current insane schedule.
I know Kevin had a Tranny issue he is looking into along with a rear broken leaf spring
I know Jim Busch said he would not be able to make this Trip.
I know Mark is looking to get his new rear axle installed, I doubt this will keep em from going.
It's a good possibility a few of us will have our repairs complete before this trip.
So who all is in ?
Going: Jim C Runoveru2
Kevin 93 Krawler
Mark Waffle (As long as Sunfire gets Rig togther)
Zack Smiddy24
Jeff. Jeepmanjeff
Robert WrenchMonkey Sat-Sun
Chris. Cvaske. Fri - Sun
Brad. Blazerbrad (Out due to Wife's birthday)
Old 08-10-2016, 12:24 PM   #2
I'll be there with something...
Old 08-10-2016, 01:16 PM   #3
I would like to make it out there, but all depends on my dads schedule.
-Zach
Old 08-10-2016, 05:15 PM   #4
No football games that weekend so a chance I could make it.
Old 08-10-2016, 05:26 PM   #5
I'd love to go but will be on my way to Moab.
Old 08-11-2016, 12:54 AM   #6
Got my propane issue fixed today, that will put me 1 step closer to making Rush trip, for those of you that Run Propane or plan too...If you loose the plug for your idle adjustment cap I PROMISE dirt and misc crap will get in there and cause problems even though Got propane said it wouldnt. The Major dust at Harlan or Windrock or wherever you may go is too much and gets into places it shouldn't.
Old 08-11-2016, 08:12 PM   #7
cvaske
cvaske's Avatar
Should be out there Friday, and stay all weekend.
Old 08-11-2016, 09:36 PM   #8
Flint
Flint's Avatar
I need a checkout run before Slade so I will try to make one day.
2000 Wrangler TJ
1967 CJ5A
2004 Tow rig
Old 08-12-2016, 01:59 AM   #9
Pencil me in for Saturday morning through Sunday.
Old 08-14-2016, 03:39 PM   #10
Probable
Old 08-14-2016, 08:34 PM   #11
Flint
Flint's Avatar
Hope to get a new steering box in by then too.
Any quick comments for a PSC box for a TJ?
2000 Wrangler TJ
1967 CJ5A
2004 Tow rig
Old 08-15-2016, 12:33 PM   #12
Trans and spring are good now. I'm ready.
Old 08-15-2016, 01:18 PM
Old 08-15-2016, 08:58 PM   #13
monkeystrong
SeƱor Monkey
monkeystrong's Avatar
I'd like to ride along if someone has an open seat.
Old 08-16-2016, 04:31 PM   #14
Not sure how many seats will be there yet. Its not looking good. Thought you had a sxs of some sort?
Old 08-16-2016, 06:01 PM   #15
My bearing and race for my rear diff won't be in till at least next Monday for my rig, upon fixing broke stud in the rear housing I noticed metal on the drain plug. After inspecting 3rd member I noticed it didn't want to spin the way it should. Took it apart and discovered top pinion bearing race cracked in 2 places. Will try my best to get this thing together, would be nice if I had a day off somewhere between now and Rush.
Old 08-16-2016, 10:23 PM
Old 08-17-2016, 12:01 AM
Old 08-17-2016, 01:39 AM   #16
Since I've never set up a ring and pinion nor have I ever used the instruments needed to properly set and adjust backlash, I'd be more than happy to learn how using your diff.
Will let ya know when I'm ready, I will be showing my boy and his buddy in the process, I quit using dual indicators years ago and only break it out when I'm setting up a diff that will be run on the street. For Hardcore offroad use you have to setup with the least amount of backlash possible without binding Ring and pinion. This helps keep em from breaking under shock load conditions.
Old 08-17-2016, 07:25 AM   #17
Not looking good for me on that weekend as it's my wife's birthday.....don't think she would appreciate me leaving town.
Old 08-17-2016, 12:23 PM   #18
Depends on what you buy her for her b day...
Old 08-17-2016, 12:32 PM   #19
Mine are always to spec, and have never failed. You sure yours aren't getting too hot?
Old 08-17-2016, 02:32 PM   #20
Old 08-17-2016, 03:26 PM   #21
No chance of getting hot..ha ha ha!!! This is my last pinion after 10 years of wheeling, 5 of those years were on 39.5..with the style wheeling that we do our gears never spin fast enough for long enough to generate enough heat to expand to cause any damage. This a significant increase in strength in any differential if setup tighter than factory. If I set em to factory specs it will not last long and will break sooner. Changing your diff grease at least 1 time a year and inspecting backlash and metal on plug keeps you aware of what's going on in there.
Old 08-17-2016, 03:30 PM   #22
I have a better picture somewhere of my pinion where it shows all of the stress cracks where all of the teeth are ready to break off, the less contact the gears have "less backlash " the lest contact point the ring and pinion have...but you have to be careful not to cross the line and go too deep and cause binding.
Old 08-17-2016, 08:02 PM   #23
I bet they get warm at windrock. That hill is a mother...
Old 08-18-2016, 08:14 AM   #24
That's the first time I've heard somebody say to set the gears up tighter than spec for off-road use. Not saying it's wrong or right and understand the theory about the shock loading, but also concerned it could cause other issues. I've always set mine up to factory specs but have also always kept it street legal and therefore need to be able to run down the road at reasonable speed (majority of trails I have ran over the years required some street driving to, or between, trails).....my road speed is only limited by the unbalanced and trail scarred 40" TSL's.
Old 08-18-2016, 12:15 PM   #25
I second the "set them up tight" mantra. Drag racers also set them up tight for the same reasons. I ran the gears on my built stock axles set up slightly tighter than spec, setup by a professional who drag raced. They are still around about 7 years (on and off-road use) after initial setup on someone elses rig. And you guys know that I beat the hell out of that set of axles.
