Old 12-19-2016, 08:32 AM   #1
ORI Relocation
Started the front shock relocation.
Made some huge progress today. Got the front ORI and new engine cross brace completed.
Old 12-19-2016, 08:40 AM   #2
Before and after pics.
Old 12-20-2016, 02:33 PM   #3
More progress today. All welds are done, air tank and PS reservoir mounts made. Now I have to paint!
Old 12-20-2016, 02:39 PM   #4
Paint and sub 50* weather are not friends!
Old 12-21-2016, 07:57 AM   #5
Looks like you got it setup perfect now
Old 12-21-2016, 10:14 AM   #6
Yep a lot of trial and error. Welding what I thought was the permanent location 3 times kinda sucked but I gained a lot of knowledge. Thank goodness I have a plasma cutter.
Old 12-21-2016, 02:05 PM   #7
tbshakie
So the original locations were less than ideal (maybe I missed this in one of your other threads)
1976 CJ 5
1984 CJ 7
1993 K3500 GMC 6.5 TD
Old 12-21-2016, 02:55 PM   #8
This all started because I did not want to remove my shock hoops I have had for years because it entailed a whole lot of work. Not moving the shock hoops compromised compression and angles of the struts that caused severe body roll as well. So after my first run I did some searching for new shock towers and found Ruffstuff had a mandrel bent set for $120 that would make the relocation much simpler. The relocation ha only taken about 12 man hours to do. So I wish I would have done this from the get go. However I have learned a whole lot and the setup is spott on now.. At least on the lift.
Old 12-21-2016, 08:13 PM   #9
Keep that plow off and take it to haspin new years
Old 12-29-2016, 10:49 AM   #10
If I was not going to be gone I would.
Old 01-04-2017, 02:55 PM   #11
ORI relocation completed.
Attachment 1
