Old 02-21-2016, 06:17 PM   #1
95 S-10 Truggy Build
The base is a 95 S-10 ext cab. I will be using a lot of parts from my 93 full size PU.
This includes:
Front axle: 79 Ford hi pinion D60, locked, 35 spline chromo in and out, drive flanges & 5:38 gears
Rear axle: Ford 10.25, locked, stock shafts.
Engine: 05 5.3, currently stock "for now"
Trans: 4L60E
T-case: NP 241
Suspension seats
Fuel cell
Rear drive shaft
The plan is to 4 link front and rear with ORI 16" struts all the way around. Cut the frame off at the rear of the cab and tube it. Trying to stay around 117" wheel base. The front will be chopped off close to the water pump. Will relocate the radiator to the rear. Tube the front and mount the winch up front.
Started on the interior today. It was nasty and there was a some alarm wiring mess that needed to come out. Someone put a push button to start it. I thought it was issues from the alarm, but it wasn't. After I got the mess out and hooked everything back up correctly, something is still wrong. When you turn the key on, it engages the starter. Sounds like the ignition switch. Gutted the interior and what a difference it made. The smell is mostly gone now.
Old 02-21-2016, 08:56 PM   #2
monkeystrong
SeƱor Monkey
monkeystrong's Avatar
Looks like a good plan. What's your timeline for completion?
Old 02-21-2016, 10:17 PM   #3
It really depends on funds. The shocks and links are a big chunk of money. I figure about two years max.
Old 02-22-2016, 07:03 AM   #4
Glad to hear you going with ORI
Old 02-23-2016, 04:40 PM   #5
Ive had mixed opinions on the ORI's, none from personal experience of course. Why the decision to go the ORI route over a coil over?
Awesome build starting here Kevin. Let me know if i can ever lend a hand.
Old 02-23-2016, 07:13 PM   #6
I like the rebound dampening the most. Not dealing with dialing in coils is a plus too. I have yet to see anyone that does what we do and not like them.
Old 02-24-2016, 06:38 PM   #7
Agreed. And, you essentially have built in air bumps. Tunability is endless as well.
One specific reason i went with coil overs instead of the ORI's....In the event of a roll over, or any damage to the shock an ORI has the potential to prevent wheeling the rest of a trip (putting your rig out of commision). CO's will continue to maintain ride height using the springs where an ORI or air shock will compress when pressure is lost. Mark's roll on Grapevine as an example.
Old 02-24-2016, 06:42 PM   #8
One specific reason i went with coil overs instead of the ORI's....In the event of a roll over, or any damage to the shock an ORI has the potential to prevent wheeling the rest of a trip (putting your rig out of commission). CO's will continue to maintain ride height using the springs where an ORI or air shock will compress when pressure is lost. Mark's roll on Grapevine as an example.
Makes sense. Hope I don't have that issue. I'll make sure mine are turned in and not out.
Old 02-24-2016, 08:49 PM
Old 02-25-2016, 08:23 PM   #9
Best part is, from now on when someone asks Kevin "how much are them purdy shocks?" I'll get to give Kevin that look he and others always gives me, lol.
I hear ya. If anyone asks what your axle is I'm going to say it's one of them 10K axles.
Old 02-25-2016, 08:30 PM   #10
Been looking at heims, and link kits. Some kits had larger lowers than uppers, some were the same size. Are 1 1/4 heims with 2" 1/4 wall tubes good for my lowers? Same for the uppers, or smaller. Buy the brackets or make them? I have a plasma cutter...
I thought the shocks were expensive, the heims are ridiculous. About a grand for 16 1 1/4 heims.
Old 02-25-2016, 09:28 PM
Old 02-25-2016, 10:37 PM   #11
underpowered
They call me......Scuba
1 1/4 is overkill for the lowers. granted, overkill is good, but 7/8" are fine. Most guys i know only run 7/8" without issue and is all i am running. Unless you beat it like a bouncer, you don't "need" 1 1/4 heims. especially on the uppers, they see far less stress than the lower do.
as for the tube, once again, overkill is not a bad thing and strength greatly depends on your over all length of the links themselves. a longer link will need a stronger material to better resist bending.
beat up rusted out k5
Old 02-25-2016, 11:00 PM
Old 02-25-2016, 11:07 PM
Old 02-26-2016, 05:04 AM
Old 02-26-2016, 07:57 AM
Old 02-26-2016, 02:59 PM   #12
I wouldn't do anything less than 2" x 3/8" lowers and even that's sketchy. To me 1/4 wall links belong on a sami. When it comes to lowers overbuilt is a good thing...
Yeah, I run 2x025 on my XJ, and it's not much more than a sami.
I bet you could split the difference, though. 2 or 2.25 by 375 lowers on a 1.25 end, then smaller/lighter/cheaper uppers.
Old 02-26-2016, 06:17 PM   #13
underpowered
Thing is, you're running 36" tires and a 10 bolt front axle where as Kevin currently runs 40" tires on 1 tons so that's not an equal comparison, you won't be wheeling where he does (no offense). Kevin might be seen at Haspin now and then, but this rig will live at the toughest obstacles at Harlan and Windrock where the stresses involved are much higher. We're talking about the need to not just survive class 5 obstacles, but the need to survive them over and over and over. Ever been in Rattlerock at Windrock from beginning to end? How about Grape Vine at Harlan in the rain? Ever see a heim break or pull out of it's threads? It's not pretty and has a tendacy to have a domino effect by breaking other parts, especially on a front 3 link. (a broken front 3 link heim can be so catastrophic that just getting it back to camp and on a trailer could be the biggest challenge). Btw, SRRS bouncers don't run $48 1-1/4" heims, they run the $100 ones at min on up to $150 a piece builder ball joints. Big difference. For example. You can buy a cheap 7/8" heim for $20 from one place or a higher quality Aurora 7/8" x 7/8" heims for $70 ea at another place. A cheap 1-1/4" for $48 ea or an Aurora 1-1/4" for $90. Lot's to consider here. It's all about compromises between strength/wear/cost/service life. FK is another good brand btw. Watch out for anything made in China. And remember, heim size is directly related to bolt and thread shank diameter.
I would never trust cheap 7/8 heims in 2" x 1/4" lower links on a 5k lb rig where this pic was taken.
Actually I am on one tons and 38.5's currently, it will be placed everywhere Kevin plans on taking his in Harlan, the badlands etc.. I understand the compromise, but as i said, it is not just me. A few guys i know (not on here) run nothing more than good 7/8" heims on their full size rigs. If you think you need 1 1/4, then by all means get them but i am just saying they are most likely overkill.
It is a lot of personal preference i guess. I'd have no concern with 2" 1/4 wall and 7/8" heims in that spot of your pic. Only time i have ever seen a 7/8" break is in a hard roll with lots of side load on them, but i've seen plenty of 1 1/4" break in that same situation as well.
Old 02-28-2016, 10:49 AM   #14
I was under my rig yesterday looking at everything I would have to transfer/redo on the s10 and decided it would better and quicker to just use the full size frame and put the s10 cab on it. My down time on the rig will probably be a little longer, but I think the overall time will be much quicker. Not having to take the drive train out will be a big help. I just have to decide when I want to stop wheelin the truck and tear it down. I still have the RZR to take on the trips.
I did some measuring and I like the numbers.
Full Size: S-10:
Frame width - 45" Frame width - 34.5" (10.5" smaller)
Body width at rocker - 72" Body width at rocker - 61" (11" smaller)
Frame height - 9.5" Frame height - 5.5" - (4" smaller)
Cab length - 57" Cab length - 70" - (13" bigger)
Cab mount to top of cab - 52.5" Cab mount to top of cab - 47.5" (5" shorter)
Overall height minus exo - 82" Overall height after swap no exo - 77"
Old 02-28-2016, 08:41 PM   #15
underpowered
Downtime will be longer, but overall build time should be shorter i would guess. seems like a pretty viable option.
Old 03-07-2016, 10:30 PM   #16
Been doing what I can till I rip the other one apart. Hit u pull for some parts. Replaced the ignition switch, and no more starter issues. Found a non a/c blower box to get rid of the huge a/c one. What a difference. Thanks Mark!! Had to replace most of the interior. Pulled the suspension seats out of rig to get them fitted in this one. I really like the space in the cab. I was expecting to feel cramped compared to the full size, but I wasn't at all. It is nice to be able to recline my seat without hitting the back window. Still looking for an auto console so the shifter will be between the seats. The stock 1500 4x4 shifter should work out in the s10 cab.
I decided to tear the rig apart after the Windrock trip in September. Hoping to have it done by the Harlan southern shine in May. That's about 9 months...
Old 05-19-2016, 07:58 AM   #17
The cab comes off tonight. I will work on wiring and other interior stuff until its time to chop up the rig.
Old 05-20-2016, 11:09 AM   #18
The rest of the truck is gone. Now I can easily roll the cab around in the garage. Time to sort though some wiring and get rid of wires I dont need.
ID:	8880   Click image for larger version
ID:	8881   Click image for larger version
ID:	8882   Click image for larger version
ID:	8883   Click image for larger version
Old 05-20-2016, 01:39 PM   #19
Looking good
Old 05-20-2016, 02:02 PM   #20
Gone, or just out of the garage?
Cut that frame in two, bolt a coupler to the back half, and sell your new "trailer" for half what you paid for the truck!
Old 05-20-2016, 06:28 PM   #21
Gone. Hit the scrap yard this morning. I got half of what I paid for the truck. $200
Old 05-21-2016, 03:12 PM   #22
Ky Mudhunter
Ky Mudhunter's Avatar
Where did you take it that gave $200? Most places I have heard only offer $50-100 right now for scrap vehicles.
Old 05-21-2016, 04:54 PM   #23
Garden st on new haven rd. 110 a ton for unclean at 3120lbs. It was like $172 and I had a few radiators and some brass to go along with it. Together it was $196.
Old 10-03-2016, 08:58 PM   #24
Almost time to start chopping. After Harlan, it's on...
Old 10-04-2016, 05:47 PM   #25
Cool...what suspension?
