Old 07-30-2008, 02:55 PM   #1
acousticrawk
The MacDaddy
Send a message via AIM to acousticrawk
yj trac bars and sway bars: ditch em?
my yj is a daily driver, its lifted about 4 inches, and has a front shackle reversal. i also DD with a loc-rite rear locker. if i remoce the sway bars and trac bars, is it going to have a hade negative effect on my jeep? i took the sway bars off my stock height cj7 with no problems. anyone here driving without that junk?
acousticrawk is offline   Reply With Quote
Old 07-30-2008, 04:52 PM   #2
after my fourth lift on 4 differant yj's, i decided to leave sway and track bars totally off. and couldent tell a differance, other than it flexed better off road. bear in mind that these were the cheap (stiffer) lifts: superlft, sky jack, and pro comp. never coughed up the coin for a rub exp or better. im sure if you hit I-75 at 85 mph regularly, you would appreciate any extra stability you could get, though
Old 07-30-2008, 05:06 PM   #3
You should have put them in the trash the day you got the Jeep ! leaf springs do not need either !
