weld on beadlocks
Just finished the install of a weld on beadlock kit. I have the tire mounted surface ground flat but wondered if anyone had leak problems and used silicone. When I broke a tire down that I blew the bead on last week I found enough mud to fill up a 40 oz. bottle inside. Gonna dump a 1/4 bag (sarges idea) of airsoft pellets in each tire before starting the bolt tightening party. Nice weather today to do some outdoor welding! :o I think I lost 5 lbs.!
leaks..... yes
always put half the bolts in (16 of 32) and used soapy water to find the holes , mark them and unbolt the lock while it is still on vehicle, tack up holes and go on last set was for tinbeater we had 1 hole for 4 wheels wasn't bad
VANILLA GORILLA
i put tractor tubes n a set years ago, but my welding skills were HORRIBLE then
![]() Last edited by cheapthrills49; 08-24-2008 at 10:29 AM. |
Got air soft pellets in the tires now and have to get a gun to shoot the leftover pellets.
What ft. lbs. should the bolts (3/8-16) be tightened to?
Sounds like 80-100 ft. lbs. translated.
80-100 is way too tight. Most instructions I have seen are less than 20 ft-lbs. Also, most people with weld-on kits usually put a layer of silicone over the welds, unless you are really confident you can do an air tight weld.
I have them at 30 ft. lbs now and the rubber gets a bit squished to say the least.
I put a bead of RTV around the weld and let it set up for a while before mounting the tires and outer ring. Never had a leak
