Danny Beach
bronco not getting compression on 4 of the 5 cylinders I checked took valve cover off every thing looks like its moving correct
what could cause that and how do I diagnose it easiest thin first HAHA :confused: :(
86 Ford Bronco |
anywhere but there
What engine is in it?
Danny Beach
351
86 Ford Bronco |
Did you check compression with a compression tester and read 10 psi. or ? I thought you had a 302 motor in the black bronco. So the bronco will not run?
Danny Beach
yeah I used a compression tester and it didn't move out of the red not enough to even register but it did move slightly
yeah I have the 351
86 Ford Bronco |
what?where?whateva.....
Have you checked your timing with a timing light?
If it is way off I would say your timing chain has stretched or tensioner broke. Take the plugs out and move the crank using the bottum pulley and see if you can rotate it back and forth, and feel sloop in the chain.(as soon as it moves it should move the cam shaft and you should be able to see the lifters go up and down)Any sloop in the chain and you need to replace it. I cant think of anything besides the timing chain that would cause more than two cylinders to loose compression. |
#7 | |
#8 | |
I meant to get a socket on the crank, but forgot... :( Hoping it's a chain issue at this point... ![]()
It almost has to be the timing chain, if it was only loosing compresion in two cyl. than I would say blown head gasket, cracked head or block. But having
no compresion in more than two cyl. its the timing chain. Get new gears and double roller chain set, gasket for the water pump and timing chain. My 79 bronco with 400m did the same thing. It killed 3 ignition modules than I replaced the chain and it was fine. Junior |
Danny Beach
I think it is the Timing chain
I tore it apart tonight and the chain was very loose the chain and gears I got fron Auto zone Look diferent so i'm not sure if I got the right thing I was hoping to get it back up for tomorrow but not going to happen :( defenitley better than replaceing a motor
86 Ford Bronco |
