Old 04-03-2012, 08:09 PM   #1
Cribbetr
Please Help!
My son has a 1995 jeep wrangler that hesitates during excelleration. I mean all the time it's so bad it can't be driven. Here is what he has done to try to fix the problem. Replaced the fuel filter,o2 sensor,fuel pump, muffler but not the catilitic converter and cleaned the throttle body. Of course his off at collage and left me to pick up the pieces (as usual ).
Cribbetr is offline   Reply With Quote
Old 04-03-2012, 08:49 PM   #2
frankensteinxj
frankensteinxj's Avatar
Red face
Originally Posted by Cribbetr View Post
My son has a 1995 jeep wrangler that hesitates during excelleration. I mean all the time it's so bad it can't be driven. Here is what he has done to try to fix the problem. Replaced the fuel filter,o2 sensor,fuel pump, muffler but not the catilitic converter and cleaned the throttle body. Of course his off at collage and left me to pick up the pieces (as usua).
did you try a tune up?
Fixed my xj and Honda.
BYAAH!!!
Old 04-03-2012, 09:17 PM   #3
NKYJEEPSTER
NKYJEEPSTER's Avatar
what kind of spark plugs are in it?? Is it a 6cylinder? Certain brands of spark plugs can make the wrangler 4.0 run very bad. Sounds dumb but it happened to friends jeep, took it to the dealer and they changed out his plugs and put the right ones in.
Old 04-04-2012, 07:34 AM   #4
tjrider
X2 on the plugs. My 4.0 would not run those "awesome" $6 a piece E3 spark plugs. They don't like 2 prong plugs. Try sea foaming it. That usually clears up stuff
Old 04-04-2012, 08:25 AM   #5
My converter plugged up on one of mine and it would idle great but would not excelerate with out falling on it's face.
Old 04-04-2012, 03:22 PM   #6
Check the spark plugs.
Old 04-06-2012, 06:22 PM   #7
Cribbetr
How did you come up with that conclusion ?
Old 04-04-2012, 06:47 PM   #8
Bigboyky
Twisted Pres
I'm the friend... I had Platnium plugs in mine and it would backfire, spit, sputter unless you really got into it. Pedal on the floor it would run like a champ. I exhausted everything I knew and took it to the dealer... Thought oh boy here we go when they told me use the cheapest plugs you can find. Total bill was under 100.
Bigboyky is offline   Reply With Quote
Old 04-04-2012, 08:09 PM   #9
tjrider
Autolites are the best plug for any jeep motor. Add some wires, cap,and rotor. And you should be gold. If not, chop the converter off too
Old 04-06-2012, 06:19 PM   #10
Cribbetr
The plugs wires and rotor cap were changed too.
