Old 06-21-2008, 11:14 AM   #1
Rubicon joints RE 3795
I have four of these..cost me $220 + shipping.
New ..never out of the box.
$180 firm Jeff....
This flex ball joint is designed for use in wishbone (Tri-link) or 3 or 4 link suspension systems. Typically this joint is welded to the control arms, then bolted to a bracket on the top of the axle housing. This version uses a 3/4" bolt to secure it to the housing. The joint will rotate up to 30 degrees. This joint could also be used in an extreme duty lower control arm application.
The joint measures 2 7/8" in diameter and 2 5/8" wide across the misalignment spacers.
Joint includes the cup, two races, the ball, a preload adjuster, and high misaligment spacers.
Old 04-03-2010, 09:59 AM   #2
Bump for stuff I can't use
Old 04-03-2010, 02:10 PM   #3
3/4" bolt... fawking sheet!
Old 07-08-2013, 06:47 PM   #4
Wow..just found these again...new price.
Will trade for ammo
Old 09-10-2015, 06:12 PM   #5
Found these again...and I found 2 more so now there's 6 total.
All 6 for $250..trades ?
