Old 04-22-2008, 08:38 PM   #1
Traxxas issues.
I have had a Nitro Rustler for roughly 10 years. It does not come out often enough. In 10 years it has had maybe a gallon and a half run through it. Lately I have been using it more and more.
On full throttle it bogs down. If it stalls, it is very difficult to start. This only happens when it warms up. I rarely run the body so it shouldnt be overheating. And the fuel is newer.
Has the electric start with the auto glowplug. And I think it has the .15 engine. Any ideas?
Old 04-22-2008, 09:08 PM   #2
Do you put oil in the cylinder when it sits? Glow plugs bad, fuel bad, o-ring on carb split, tank has a crack or fuel hose letting air in, check temp of head to be sure carb is not clogged. They can be finiky!
Old 04-22-2008, 09:19 PM   #3
Did the same with brand new fuel, and has a new glow plug. Fuel hoses are all new. Usually I put the oil in. Every once in a while I forget. What about carb adjustments? I have heard if one thing is out they run bad. I have also heard carb adjustment is very difficult.
Old 04-22-2008, 10:07 PM   #4
o-ring and tank okay? idle screw easy. mixture screw tricky. Need a temp guage to set it. Wonder if compression is an issue. Same brand of fuel?
Old 04-22-2008, 10:44 PM   #5
OH-cj5
I had a rustler years ago if you hit the gas and it bogs but poors a ton of smoke out you need to lean it out and just the opposite if you hit the gas and it bogs but no smoke richin it up
OH-cj5 is offline   Reply With Quote
Old 04-22-2008, 11:19 PM   #6
No different bramd of fuel. Ran it again and paid close attention to it. It blows lots of smoke. Any idea how to lean it out?
Old 04-23-2008, 06:58 AM   #7
the larger screw on the carb. go 1/8 turn increments in till it is ok.
Old 04-23-2008, 04:01 PM   #8
If this thing causes you too much trouble you can always fire it up and throw it in a fire and watch it burn! I have done this a time or 2 when they get to me.
Old 04-24-2008, 04:36 AM   #9
4RunnerAdam
4RunnerAdam's Avatar
Take it to Pit Row Hobbies and ask for Guy. He set up my Savage a few years ago for me.
Man, now your making me want to get back into r/c......
Old 04-24-2008, 05:03 PM   #10
OH-cj5
Hey truggy remember what happens when you throw a half a gallon of that nitro fuel in a fire almost lost a 1-1979 chevy truck 1-car trailer and 1- jeff pendegrass LOL that dude was screaming like a girl what a hell of a way to wake up in moring with your pants on fire and not to mention the bottle going across haspin acres at mach9
Old 04-25-2008, 08:37 AM   #11
Thats usually what I do but I wanted to see if I could do something before I make the journey
