Old 06-06-2007, 11:33 AM   #1
Valve cover gasket
I am working on my mustang with the 4.6 modular motor and the gasket on the valve cover made of rubber seems to have grown. It is made to be reused, but when I went to reinstall it in the groove in the valve cover it had grown and would not fit. I put it in the freezer and that helped a little but not enough. I paid good $ for this reusable rubber gasket for the valve cover so that when at the track I would be able to do inspections and reinstall it. Anybody have any suggestions? :confused:
Old 06-06-2007, 11:45 AM   #2
sounds like it came in contact with substances it shouldn't have...
brake fluid, diesel, gasoline, etc... these all will soften and swell rubber. As far as getting it back to shape i have no idea, but make sure you have no foreign substances getting to it...
Old 06-06-2007, 01:09 PM   #3
I wonder if a chemical exists that will bring it back to shape? Had a methanol problem late last year, but I had thought that it was not that bad.
Old 06-06-2007, 01:32 PM   #4
i dont believe anything will take it back to shape... once the rubber compound has been compromised, i think it's done.
Old 06-06-2007, 07:37 PM   #5
if the freezer didn't do it... I think you'll have to buy another. :o
Old 06-06-2007, 10:20 PM   #6
If it was used and then you took it out of the valve cover, then I see how it grew. Those gaskets are made to swell after they get oil on them. This is how they make a good seal. This is also why you dont take these gaskets out of the valve cover. You will need a new one.
Old 06-07-2007, 07:57 AM   #7
As stated in an earlier thread, the gasket is designed supposedly to be reused. It shot out of the valve covers groove like a jack in the box.
