Old 04-24-2010, 10:15 PM   #1
boomhauer
boomhauer's Avatar
It's done
finally after 3 months and a complete frame up she is going out tomorrow for her 1st shakedown run
ID:	2484   Click image for larger version
ID:	2485   Click image for larger version
ID:	2486   Click image for larger version
ID:	2487   Click image for larger version
Old 04-24-2010, 10:39 PM   #2
very nice...
Old 04-25-2010, 02:20 AM   #3
tubehead
Glad to see you all got it done. Good luck with the first trip out. Hopefully see you guys at Slade for the fundraiser.
www.roarkfabrication.com
Old 04-25-2010, 08:30 AM   #4
buckeyezuk
wheeler
buckeyezuk's Avatar
jeep
Looks good man...hopefully will be wheelin with you in a few weeks..
Old 04-25-2010, 11:25 AM   #5
began
began's Avatar
looks NIce
Old 04-25-2010, 06:31 PM   #6
Looks Good! How did she do today?
Old 04-25-2010, 06:54 PM   #7
tinbeater
tinbeater's Avatar
Looks good. See you all in a few weeks.
Old 04-26-2010, 03:44 AM   #8
mike shelton
boomy
well if it means anything, it did blazer with no winching !!!!! gabby
Old 04-26-2010, 06:10 PM   #9
boomhauer
boomhauer's Avatar
never pulled cable all day !!! does seem to drop a couple of cylinders when she gets up to running temp and you want to climb something (any ideas) but other than that was very pleased with the rest of it performance wise. this is one very well built jeep. once we get the motor right it be be a point and go rig i believe
Old 04-26-2010, 08:03 PM   #10
Looks great Boomie... Congrats to you and Casey!
Up the "V-groove" of Blazer, or is there still that "eaiser" section on the right as you approach?
Tell us more of the dropping cylinders...
Old 04-28-2010, 10:33 PM   #11
boomhauer
boomhauer's Avatar
there is no easier side anymore, pretty much gotta get your front up on the left and walk the rear to the right till you get a line and shoot it. don't really know how state it really ran great till go to upper devil's brew then just laid on it's ass. running prolly on six of eight. thought i had it worked out so went today and flat ground watch out. runs like a scalded dog but put it in low range and play uphill for any amount of time and it just loses power. any ideas anyone?
new tps and tfi on it. of course plugs and cap and whatnot are all new. only coil, comp., map sensor are used i thinkand injectors
Old 04-29-2010, 02:21 AM   #12
not map... you have maf (mass air flow)
My speed density setup has a map sensor... but I digress...
Hard tellin' without being at the thing... you know the drill... has to be one of four things... air, compression, fuel or spark...
Didn't you say that an injector was ugly or something?
Guess I'm just askin' if you're sure it's spark related?
You called Amos already and *****ed, didn't you?
Old 04-29-2010, 07:00 PM   #13
8UP
On a FI motor that runs poorly uphill only I'd be looking at a fuel delivery problem. Pickup uncovering, weak pump, collapsing screen or hose, filter etc. Any chance something is shifting under load, including the engine, causing a fuel line to get pinched or a wire to rub? It's probably going to be something dumb.
Old 04-29-2010, 11:19 PM   #14
i was telling a friend of ours that screws with 5.0l's alot in hotrods, and the first thing he asked was how were your injectors. he said to try and isolate which cylinders are cutting, then try swapping injectors and see if it changes anything. he thought it seemed fuel related too.
good to hear its working, we're hoping to get joey's and mine out on sunday before they head to the RCQ next weekend.
