Old 05-31-2010, 08:12 PM   #1
3 Link Question...
I am having to 3 link the front of my Sammy-ish rig due to clearance issues. My question is, should the upper (frame) mount for the panhard be to the inside or outside of the frame?
Thanks!
Old 05-31-2010, 09:13 PM   #2
Nuts's Avatar
Put it outside, that way the panhard bar can be as long as possible and won't pull the axles to 1 side as bad when it drops out. Also if you have normal steering(not full hydro) keep the panhard bar parallel with the drag link.
Old 06-01-2010, 12:31 AM   #3
What's not clearing that won't allow a 4 link?
Old 06-01-2010, 03:12 PM   #4
Thanks! I have full Hydro.
That little thing on the bottom of the engine called the "oil pan"...
Old 06-01-2010, 10:02 PM   #5
tinbeater
tinbeater's Avatar
If you have hydro steering I would run a 4 link set up. I dont understand why you cant clear the oil pan.
Old 06-02-2010, 12:52 AM   #6
REverse the triangulation of the bars that aren't clearing the pan... there shouldn't be any reason it wont clear...
fark 3 links and panhards... they are the suck. might as well run a radius arm setup.
Old 06-02-2010, 03:22 PM   #7
I will try and get a few pics up this evening...
