Old 05-06-2011, 07:09 PM   #1
best place to read tranny temps
Turbo 400.. where's best place to tap into w my gauge?. Line to cooler, line after cooler, somewher else?. Or does it matter... seems like it would.
Anyone ever run a gauge to see what drop ur gettin over the cooler,btw?
Old 05-06-2011, 11:30 PM   #2
In the line to the cooler gives you the worst case scenario or what the trans is actually seeing. That's where I would go.
I have heard about some people in diesel trucks running dual gauges until they get their cooler sized right.
Old 05-07-2011, 01:18 AM   #3
Two sending units, one gauge with a switch to go between the two senders. Run one sender on the line going into the trans, and one on the line coming out. Then you can switch back and forth and see how well your cooler is actually working.
I ran mine to a test port on the side in the last rig. It was a bad idea, as it reads a lot higher than the actual fluid flow. I had it in mind to change to the dual sender, but sold it before I got to it.
Old 05-07-2011, 12:21 PM   #4
Awesome idea. That's how ill do it... best of both worlds.
Old 05-16-2011, 10:20 PM   #5
when i first read the thread post i Thought you were up to your old ways again.... dang Trannys get ya every time
Old 05-16-2011, 10:43 PM   #6
lmfao
Old 05-17-2011, 09:16 AM   #7
muskrat!
