Old 10-24-2012, 11:04 PM   #1
strange popping in rear end
ok folks i worked on this sami all last week and it is still popping in the rear end..
here is what i did.
1. it had 4.62 gears - pulled pig and locker was trashed.. so i figured time to swap in the 5.38 gears which i had in another axles set from splattt.
2. swap front axle out with 5.38.
3. put in 5.38 pig with locker in rear.
4. rear left side still popping when turning or gettin on the gas going straight..
At this point im thinking the lockers are bad...
called up lowrange - they said lock rite lockers are out of business 1530 lockers are no more...
so I ordered a spartin locker and side gears...next day air got it thursday morning and put the new locker in the 5.38
looking at old locker it looked ok and did not have any chips or rounded corners on the locker so i set it aside..
put everything back together..
5.38 in axles.
still popping...
thought maybe it is the axles shafts... or tcase.. pulled axles and put in new ones.
still popping
said ok lets swap put the old locker in the 4.62 gears set and see what happens..
put it in the axles and still popping..
lifted the axle off the ground and spun the rear in gear and it popps on the left side..
so as it sits...
2 separt 3rds both with 2 different lockers. both are popping on left.
5.38 - new spartan locker
4.62 - old lock rite with new side gears new springs
Im at a loss as to were to go from here unless i set up the lockers wrong.. but i followed the specs sheet..
:confused::confused:
oh yeah this is the reason I missed fall crawl... 5 people can not fit into 3 SEATS.. NEEDED BOTH RIGS..
Gatlinburg is where we went...
tried to make the best of things...
Old 10-25-2012, 06:13 AM   #2
It sounds like it needs piston rings .and a fuel pump.
Old 10-25-2012, 06:33 AM   #3
Bearings in outer axle or breaks?
Old 10-25-2012, 07:04 AM   #4
I also say axle bearing, I had one do this before on a Toyota which I believe is the same setup. Pull the axle- an ok or new one will have slight slop in it, if it has any more than slight then its junk. Trust me you will be able to tell, a lot of people overlook this.
Old 10-25-2012, 07:44 AM   #5
drmeece
drmeece's Avatar
Sounds like you"ve been eating Mexican food
I got a jeep
Old 10-25-2012, 08:46 AM   #6
Take the wiper motor apart and u will find your problem
Old 10-25-2012, 12:36 PM   #7
Possibly a bent housing
Old 10-25-2012, 09:12 PM   #8
I would change the oil and adjust the seat first
Old 10-25-2012, 09:23 PM   #9
LP78CJ
LP78CJ's Avatar
too much air in your left front
Old 10-26-2012, 01:44 AM   #10
yeah I will have to check this..
i did not check the axle outter bearing but check that an easy fix..
thought that too... but all in all I can swap out the axle housing also and try that after checking 3rds and axle bearings...
Old 10-26-2012, 05:44 AM   #11
Can someone else drive it while u walk behindand determin if sound is from pumkin or the side?
Old 10-26-2012, 07:10 AM   #12
i raised up the wheels off the ground and put it in gear.. then I just pushed the brakes as the wheels turned and it started to pop..
maybe ill have to make a video....lol
