Old 10-17-2018, 10:06 PM   #1
Jeegy upgrades!
Well I have been convinced after Harlan and watching Others, cough, cough, all weekend that I need more HP and a smoother shifting experience in the woods. Hence I bought a 6.0 LS LQ4 tonight with 91,000 on it. I also last weekend bought a TH400
So far I have ordered this for the upgrades:
Transmission cooler
Derale 15800 Electra-Cool... [ame="https://www.amazon.com/dp/B000CN6TPU?ref=yo_pop_ma_swf"]Amazon.com: Derale 15800 Electra-Cool Remote Cooler: Automotive[/ame]
Tranny rebuild
https://rover.ebay.com/rover/0/0/0?m...2F171338232536
Seat belts
Driver Restraints 3 in. Complete Set 3 in. Cam Lock Wrap Around Black Pull Up Straps [ame="https://www.amazon.com/dp/B0006HKL4W/ref=cm_sw_r_cp_api_6B-XBbV3ZCKCE"]Amazon.com: Driver Restraints 3 in. Complete Set 3 in. Cam Lock Wrap Around Black Pull Up Straps: Automotive[/ame]
Atlas 32 spline input kit
Advance adapters Th400 to Atlas transfer case
Need these items that I can think of
Torque converter
Power steering pump bracket for my Howe pump
Bracket for my York compressor
License for ECM
FUEL PUMP
FUEL FILTER
Radiator lines and what not
Winters shifter
Throttle cable
Exhaust
If anyone has information on the items left to get or can think of anything else I might need add it to this thread
Old 11-18-2018, 10:01 PM   #2
Old 11-18-2018, 10:05 PM   #3
Attachment 1
Old 11-19-2018, 03:44 PM   #4
Looks pretty snug. Any issues?
Old 11-19-2018, 03:47 PM   #5
Yep. Coil packs. Gonna look into it tomorrow
Try to maneuver it better. Zach won’t want hear this
Old 11-19-2018, 08:47 PM   #6
You can always relocate the packs and get longer plug wires. Are they all in the way or just a couple?
Old 11-20-2018, 10:31 AM   #7
I mentioned flipping the coils backwards (if that's possibly) and getting a longer set of wires. Lester also came up with a good idea on Facebook. I guess Jegs sells this rack where you can mount and hang them in any location you need.
https://www.jegs.com/i/UNKNOWN/335/5...MaAiUZEALw_wcB
Old 11-20-2018, 11:01 AM   #8
Just one. I am going to stand it up right and make little tabs for it.
Old 11-25-2018, 10:18 AM   #9
Old 11-26-2018, 02:04 AM   #10
Wiring done today
Old 11-28-2018, 08:54 PM   #11
Got the water pump tapped for the thermostat and steam port done. Needed a 3/8 and 1/2 pipe die (harbor Freight $11.89)
Got the shroud cut out for the Volvo fan as well
Ken Garcia did the aluminum welding for me. Doing AN 16 fitting and stainless steel lines
Old 11-28-2018, 09:57 PM   #12
Looking good. I have 1/4-3/4 npt taps and 1/2 - 1 1/4 dies if you ever need them.
Old 11-28-2018, 09:59 PM   #13
I have 1/4, 3/8 and 1/2 pipe tap and dies as well now
Old 11-28-2018, 09:59 PM   #14
Better known as NPT
Old 11-28-2018, 10:02 PM   #15
I also got a sweet bearing set driver if you need to borrow it as well. It has some small drivers in it that we needed for the TH400
Zach’s kit will be here this week. I bought everything g we need to do it and a kick ass book for it as well. Has color pictures and shows how to mod them as well
Old 11-29-2018, 06:49 PM   #16
I ended up buying a bearing kit too. Got tired of not having the right tool for the job. This kit has stack-able pucks for about any size combination.
Old 11-29-2018, 09:46 PM   #17
What bearing set?
Old 11-29-2018, 09:49 PM   #18
The radiator is installed and lines ran
I really like the AN16 lines. Well worth the money to do these. Really is not that expensive to do.
Old 11-30-2018, 03:23 PM   #19
Those are really really cool, but that's only like 7/8 ID, right? Is that going to be enough flow?
Old 11-30-2018, 11:58 PM   #20
1” is what I bought. Everyone has said yes it will
This is also what they run on the NASCAR cars
Old 12-01-2018, 12:01 AM   #21
More progress made
Old 12-01-2018, 01:42 PM   #22
Cool! Let me know, that could help with a packaging issue I'm having too.
Old 12-03-2018, 08:32 PM   #23
Old 12-04-2018, 12:38 AM   #24
You managed to cram the york in? Nice!
If it's facing backward, does it spin the opposite direction? Does it mind?
Old 12-04-2018, 09:24 AM   #25
AES is sending one that is reverse rotation for me at no charge!. This company is fantastic!
