Go Back   C.O.R.E. FORUM > Support and Testing > Get Help
Old 04-23-2007, 07:31 PM   #1
How come....
When I went back and tried to edit the title of my "Stihl MS 290" post in the for sale section it doesn't change the title even though I made the alteration?
Not *****ing just figured that I was doing something wrong!
Jeff
Old 04-23-2007, 07:37 PM   #2
database issues today, try again later....
Old 04-24-2007, 02:22 PM   #3
I thought that you couldn't edit the title... I've gone back to edit the title block and nothing happened... maybe I'm not remembering correctly.
Old 04-24-2007, 02:24 PM   #4
nevermind, just did it and it worked fine.:confused:
Old 04-24-2007, 02:31 PM   #5
well, you are an admin Brad.... i don't think a normal user can edit the title... hmmm, not sure if it's a setting i can change or not.
hey Jeff, try it again, and let me know if you can. or anyone else for that matter.
Old 04-24-2007, 02:47 PM   #6
works fine, anyone can change the title of their threads, but you have to go into the "advanced editing" not just the quick pop-up edit within the same thread window.
make sense?
Old 04-24-2007, 09:50 PM   #7
Nope... I went in and "went advanced" and it let me type in a new thread title but it did not post my change. It shows the change in the "title:" area and has it saved as I could see my alteration from 4/23 but it does not show up on the forum section listings.
This is not the only forum board that works this way , I didn't know if this was a glitch or if when you (Mike/Brad) set up the new board that you selected this as a mod only privilege?
No biggie , Jeff
Old 04-24-2007, 10:11 PM   #8
WTF, I even tried to modify your post... and didn't change for me either...
Works/worked in the testing area... I think I'm as confused as you Jeff... Unless the "For Sale" section is specifically set up so folks can't change it?
Whatever, going out in the garage for a while, I've had ENOUGH of computers tonight.
Old 04-24-2007, 10:48 PM   #9
Let me have a shot at fixing it. I think I have what it takes to get the job done. I will use one of these red things I have with a long wick on it and place it under the computer and see if blowing the hard drive up into little bits helps. Heh!
