Old 07-07-2012, 04:43 PM   #1
mossyoaktj
mossyoaktj's Avatar
tj wipers dont work
I have a 99 tj amd well the wipers don't turn on. At first I would have to give the wipers ARM a little pull and they would work. Then a little while later nothin at all. Recently i put a switch in and still nothing, the fuse is good. So I'm thinking I need to replace the motor. Any other ideas
UNITED STATES MARINE
Old 07-07-2012, 05:31 PM   #2
If you had give them a boost before, I would say the motor was on its way out.
Old 07-07-2012, 06:06 PM   #3
damn motor
Old 07-07-2012, 08:36 PM   #4
tjrider
X3 motor. Take ALL the screws out pull the cowl. Its right there, easy peasy
Old 07-07-2012, 09:38 PM   #5
mossyoaktj
mossyoaktj's Avatar
Yea ive had the cowl apart to check the motor before and magically the day I checked it it worked fine. That was a long time ago.
Are xj motors the same as the tj?
Old 07-07-2012, 11:25 PM   #6
tjrider
Not sure, but it kinda sounds like a bad ground
