Old 04-10-2012, 01:01 PM   #1
frankensteinxj
frankensteinxj's Avatar
Sneak peak build pics
Heres a few pics of how the ton swap is going.
Almost done, hoping to make the deep run free day in 2 weeks.
a few weeks ago, sterling in and moveable
d60 with artec truss
d60 mocked up.
air shocks mocked up
Good ole radius arms getting tacked inplace.
All I need to do from here on is strengthen the unibody and crossmember.
Get the passenger seat and harness installed.
Panhard bar.
check the new master cylinder from dodge 2500 and bleed brakes.
Steering box.
A little cage work that will probably be held off for a few weeks due to lack of good bender.
I havent taken many pics but figured Id post the ones I got.
BYAAH!!!
Old 04-10-2012, 03:14 PM   #2
Looks wide and heavy duty..
Old 04-10-2012, 03:25 PM   #3
Jonesy
Jonesy's Avatar
I'm really digging the Artec stuff, looks like a top notch product.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 04-10-2012, 04:16 PM   #4
frankensteinxj
you know it.. the front is almost done and should be rolling early next week.
Yeah I love the artec stuff.
I was gonna build my own truss but i love the artecs and figured, hell Ive spent enough money might as well get a good looking truss on it.
BYAAH!!!
Old 04-22-2012, 01:46 AM   #5
frankensteinxj
Front end is pretty much done.
little **** left. fluids, driveshafts, cage work
BYAAH!!!
Old 04-22-2012, 10:43 AM   #6
Looks good..I can't wait to see it on the trail.How did you make out on getting a wider trailer to haul it?
Old 04-22-2012, 11:34 AM   #7
frankensteinxj
found a standard 82" between the fenders on clist.
Ill just have to go over the fenders. It is only 84" wide now but when I get my beadlocks done it will be about 86.
BYAAH!!!
Old 05-01-2012, 04:31 PM   #8
frankensteinxj
READY TO WHEEL!!!!.
Got the brakes figured out. Im using a 98 dodge 2500 mc with a 95 dual diaphram xj booster and stock prop valve. After I got it together the brakes were complete ****. Well..... I forgot to bench bleed the master cylinder so I did that today and it locks up the 38s. .
Poser pics and checking out the suspension and shocks to check travel. The cage works really well as bump stops.
BYAAH!!!
Old 05-01-2012, 07:08 PM   #9
u&k metal works
u&k metal works's Avatar
Looking good it's about time lol good job
Old 05-04-2012, 04:34 PM   #10
Sweet, looks good...Thats the same master cylinder I used on mine.
I can't think of a better place to put it to the test than Harlan during the Southern Shine.
Old 05-04-2012, 05:04 PM   #11
frankensteinxj
I took it down the road today.
During this build I had no intention of street time but after seeing how well it did today Im considering tagging it and cruisin it every now a then.
It probably wont see harlan for a few months.
Wanna see if i can destroy it a little closer to home first.
BYAAH!!!
Old 05-27-2012, 01:12 PM   #12
frankensteinxj
Alright I lied... It wasnt done.
I messed up mounting the air shocks so I had to cut my tabs off and put some new ones on.
I also hated how I had my panhard mounted so it got redone. At first I tried a ruffstuff bracket and tried the artec one but neither one of them would work so I broke out my new chop saw and started making my new mount out of some 1/4 plate a few gussets and some angle iron.
New airshock mounts from artec built to the contour of the truss.
New panhard mount.
Panhard angle is a littl off until I get these bad dogs on there in a few weeks. Going full high steer and hydro assist at some point.
BYAAH!!!
Old 06-03-2012, 12:07 PM   #13
frankensteinxj
Alright.... I pretty much hate this jeep at this point.
Still havent taken it out this year cuz its still in the garage.
So sick of not wheeling!!!!!!!
On that note... Im going to go work on it now.
.l..l.
BYAAH!!!
Old 06-14-2012, 02:45 AM   #14
frankensteinxj
IT LIVES!!!! ...... (again)
BYAAH!!!
Old 07-05-2012, 12:58 AM   #15
frankensteinxj
Last year before the build
This year same spot
Ran once without beadlock and this happened.
So I fixed that problem thanks to zach at u&k metal works.
Last trip out, no problems besides a bent roll bar so Im gonna work on the cage a little more...Heres a start
BYAAH!!!
Old 07-05-2012, 10:30 AM   #16
Incommando
Would removable fenders work out? Pop them off and drive over the trailer tires?
Old 07-06-2012, 02:34 AM   #17
frankensteinxj
That is what i will end up doing.
Right now with my beadlocks the tires they squeeze right in between the fenders so Ive just been runnin it the way it is.
BYAAH!!!
