Old 09-21-2007, 11:06 AM   #1
scarface
I beat anorexia!
scarface's Avatar
wheel adapters?
whats everyones opinion on wheel adapters? I am thinking about buying a new rear axle and it is 5 on 5.5. all my wheels are 5 on 4.5. just wondering if it is worth it
Old 09-21-2007, 11:11 AM   #2
they are safe, i used to use wheel spacers, 4" ones in fact, on the back of my last jeep...
problem is the adapters will make you wider just like a spacer, by at least an inch or so each side.
Old 09-21-2007, 12:11 PM   #3
scarface
I beat anorexia!
scarface's Avatar
that isn't bad in my book, I want to be a little wider anyway. Do you sell adapters mike?
Old 09-21-2007, 01:05 PM   #4
4RunnerAdam
4RunnerAdam's Avatar
You can get them at www.aimind.com
Just make sure you re-torque them after an initial 100 miles or so. Then check them every so often afterwards. Aluminum will expand and contract and loosen up the lug nuts, and since you will have 10 per wheel now it will be important.
Old 09-21-2007, 01:08 PM   #5
I don't carry them, sorry.
Old 09-21-2007, 01:17 PM   #6
scarface
I beat anorexia!
scarface's Avatar
I almost think for that price I will get the Super 88 kit for it. I was looking at this site just for ideas... google
http://www.ezaccessory.com/Wheel_Ada.../5550-5450.htm
Old 09-21-2007, 01:36 PM   #7
scarface
I beat anorexia!
scarface's Avatar
http://www.jegs.com/webapp/wcs/store...0002_192370_-1
this one looks pretty dang cheep though
http://www.jegs.com/webapp/wcs/store...0002_804698_-1
that one isnt bad
Old 09-21-2007, 01:50 PM   #8
I have welded up the holes before and put a new bolt pattern in the axle shaft before but would not be comfortable doing that on a daily driver. I have wheel spacers on the truggy. 3.5'' in the front and 2'' in the rear and run them on the mustang too! Be sure to recheck the torque and use locktite.
Old 09-21-2007, 05:03 PM   #9
ran them on all four corners of my camaro to fit the ZR1 rims , all of them were 2" . I'm going to run them on the Jeep as soon as I find a good deal on a set.\
What axle are you looking at putting under your XJ that's 5 on 5.5 ?
Old 09-21-2007, 08:51 PM   #10
eighty3bronco
anywhere but there
eighty3bronco's Avatar
most likely an 8.8
Old 09-21-2007, 09:40 PM   #11
scarface
I beat anorexia!
scarface's Avatar
Originally Posted by eighty3bronco View Post
most likely an 8.8
dat be correct
Old 09-21-2007, 11:13 PM   #12
ok ! most people use the 8.8 out of an explorer for a jeep swap ! 5 on 4.5 and 31 spline shafts.
Old 09-22-2007, 12:36 AM   #13
scarface
I beat anorexia!
scarface's Avatar
Yeah this one came from a bronco so it threw me off a little. but it is full width or darn close
Old 09-22-2007, 01:38 AM   #14
are you going to run spacers on the front ? All of the coversion adapters that I have seen give you at least 1.25" width , these on a full width in the rear are going to be much wider then the D30 in the front . 3"-4" spacers on a D30 is going to put a heck of a lot of stress on your ball joints and unit bearings.
Old 09-22-2007, 03:00 PM   #15
Think .. scrub radius!
Old 09-23-2007, 01:26 AM   #16
scarface
I beat anorexia!
scarface's Avatar
I didn't plan to run spacers on the d30. I am going to beat it how it is and see how long it lasts. I plan to pick up a 44 or 60 for the front sometime next year and get it ready for the next time it goes under the knife
Old 10-02-2007, 06:57 AM   #17
I just ordered these for the YJ , should be dropped off by the brown Santa today !!
http://www.jeepforum.com/forum/showthread.php?t=287925
Old 10-02-2007, 08:07 AM   #18
scarface
I beat anorexia!
scarface's Avatar
tell me how ya like them, I will probably order a set later this week
Old 10-02-2007, 11:18 PM   #19
Brown Santa came threw !! got them this afternoon and mounted them up ! took the little one to soccer practice with no Bump Steer or any other ill effects . They look very stout and well made. Jeep looks good too !
Old 10-03-2007, 09:32 AM   #20
scarface
I beat anorexia!
scarface's Avatar
Sounds good, I am now trying to decide if I want a 14b or not
Old 10-03-2007, 09:59 AM   #21
14 bolts are tough. Only problem is the pumpkin diameter. With a grinder and a welder you can clearance it and put disc brakes on it and wheel.
Old 10-03-2007, 10:24 AM   #22
does the 1-1.5 inches really make that much difference? I never once had the lip on my 14b keep me from making an obstacle.
Old 10-03-2007, 10:47 AM   #23
Ask Brody about it. In west virginia he and pat had one hell of a time with their rear diffs hanging them up. Depends on the terrain and the drivers ability I suppose. I love the 14 bolt for its strength!
Old 10-03-2007, 11:05 AM   #24
scarface
I beat anorexia!
scarface's Avatar
This one comes with disks already and a lincon locker(dont know crap about them) for a cheap price. I plan to take about an inch off the bottom and lose the bottom bolt. I figure for what I lose in clearence I gain in strength and width
Old 10-03-2007, 11:18 AM   #25
Sounds like an excellent plan to me! Build it!
