Old 07-24-2013, 09:16 AM   #1
i hate me
toyota crawler
ok I hate to do it but I need to put it up for sale :( i will part it out ok I have a tube chassis that is 1 3/4 dom on a toy frame the frame is plated where the tubing connects very solid frame !!! I have a never fired rebuilt 22re with after market camshaft new timming chain steel guides oil pump pistons and so on i have 2 5 speeds new clutch set for it 2 transfer cases 1 top load with 4.70.1 for 21 spine front and rear axles are trussed hardened bolts welded in for centers to bolt in both axles have diff armor and 3/8 thick plate on underside to beat on rocks and not hurt the housing 4:11 gears front has locker i was going to weld the rear but haven't yet front axle is complete with dirty 30 chromoly axles 6 shooter knuckles all new seals bearings creeper flanges and super stud kit sealed breather kit for front and rear axle orbital valve for hydro steering with the mounting plates with steering wheel disconnect nice five point racing seats and tracks trail gear hydro pump and bracket gm 1 wire alt bracket solid pionon spacers front and rear transfer case shift boots and heavy duty shift springs trunnion bearing eliminators trail gear motor mounts 18 inch fox shocks and im sure i have forgot to mention a lot of stuff if you wondering just ask i didn't cut any corners I WILL PART IT OUT .. a dual case adaptor propane kit and hydro ram away front having about all the large items i have over 7000 in it i would be interested in a wrangler for a daily driver or maybe something else cash is king cash and trade im open to all offers just bought a house and im not going to be able to finish it 740-497-1423 im chuck
ID:	6895   Click image for larger version
ID:	6896   Click image for larger version
ID:	6897   Click image for larger version
ID:	6898   Click image for larger version
i hate me is offline   Reply With Quote
