rear ford 9" ready to bolt in ZJ
i am selling a ford big bearing 9" rear end out of my ZJ.
full width 78-79 year F150 big bearing converted to chevy disc brakes coil buckets and shock mounts for ZJ setup 4 link trussed and gusseted Yukon 31 spline shafts Detroit locker 4.56 Yukon geared 1350 pinion with HD pinion guard 1/4" thick rear armor cover (with drain plug) breather on top of centersection shaved 1" 5 on 5.5" ford bolt pattern. 1/4" link mounts (flush with axle housing) the only bad things are: will most likely need a new pinion seal, it leaks a little gear oil from the pinion the ends of the housing leak gear oil a little too complete and ready to roll 1000.00
http://pirate4x4.com/forum/showthread.php?t=766227 Last edited by ohiozj; 01-22-2015 at 07:42 AM. |
