Old 06-19-2015, 02:25 PM   #1
ohiozj
ford axles hp44/9"
I am parting out the heep. axles are up for sale.
front is a HP ford full width d44 that had the welded on wedges cut off. its got a tnt truss on it set up for a standard front 4 link and track bar setup. rebuild all the outers. Yukon 456 gears, lockrite locker, stock shafts and joints. warn premium hubs. set up for over the knuckle steering. rockkrusher diff cover. comes with a long side factory spare inner and outter.
steering can be included if needed. its all homemade 1-1/2" .25" wall tube. set up for assist steering. assist can be included if needed as well (price negotiable)
rear end is a full width big bearing for 9" trussed shaved armored and disc braked. set up for triangulated 4 link with clayton truss. Yukon 456 gears and Yukon 31 spline shafts. detriot locker. chevy calipers, ford rotors. 1350 pinion and GLO pinion guard.
these came out of a zj so would bolt right up with little mods.
$1500
ohiozj is offline   Reply With Quote
