Hvac
Who is the heat and air guru
I have a rheem classic 90 about 4 years old started in the spring thought it was low on propane but is still doing it this fall will cycle and heat like it should then cycle off next time it will cycle blower will kick on cycle back off b/4 it should, kinda like it runs out o propane ? will cycle on off on off on off several times without lighting, will go in shutdown mode... I guess is what it would be called 10- 15 minutes later will go thru the same **** sometimes it will light and run sometimes it wont thermostat cause this? HELP..
