Old 08-18-2010, 12:43 PM   #1
fmlewis
The best damn Engineer!!!
Marker Lights
Hey yall.
I am building a CJ7 with a fiberglass tub/body. I purchased a new ezwire wiring harness and I am attempting to get my marker lights to work. i.e. - when the headlights are turned on my tailights and turn signals should be turned on slightly dim from normal operation.
I have jumpered a 12V signal to the circuit and the lights light up so I know the wiring is correct. The issue with this is that they are too bright when I use the brake pedal they do not signal that I am braking.
When I plug in my headlight switch and pull the knob the markers do not turn on only the headlights do.
Any ideas?
I have tried 2 new headlight switches and still no luck with markers.
The interesting thing I found was that there is no continuity between the power/supply terminal and the marker light terminal on the headlight switch.
Help!!!
