Old 02-27-2013, 07:26 AM   #1
BillysGruff
Goats on the Roof!
BlueOx build
Hopefully the name hasnt been taken already. I've always called my truck that. 2003 Silverado thats been through the wrenches. Its been in two wrecks, neither my fault...so once the trans went, that was the last straw for me. Plans are leaf sprung 52's, 4.88's, 37's/Hummer beadlocks combo from Trailworthfab.com. It will be a dual purpose vehicle. No thrashing till exo, shorten rear, and no bed. On with the pics...
I always liked this pic
NP241C D-drop
Gear pattern for 9.5
BTF diff cover
Closeup
Running stock brakes, poor tape measure
U-bolt flip
Shackle flip
1330-1350 conversion u-joint
9.5 Installed
Press brake that is functional, but still needs some work
Trans parts, piece of .375", 9/16" socket
Locking collar needs some work
Start of winch bumper, .375" base plate, .188" brackets holes matching to frame for bolt on, 14* bends on bottom piece, tube is 1.75" .188" wall CREW
Got this hunk of **** for 1K locally, man it needs work
Any body need an HSA?
'78
Missing a couple lockout pieces on both sides
Rear end pic
And a face to match the name, poser shot, stock truck
Currently I'm waiting on '89 rotors and new 14x1.5 studs. I'm currently searching for hub parts, have some not local friends with parts, but I'm thinking my best bet is a boneyard. Thats its for now. More to come.
BillysGruff is offline   Reply With Quote
Old 02-27-2013, 09:07 AM   #2
Jonesy
Jonesy's Avatar
Looks like a great start. I would love to have a SAS truck like this.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 02-27-2013, 07:28 PM   #3
histeer arm looks like death trap, **** mud boggers do! id keep bed and dovetail for looks, also it will not stay dual purpose for long so spend wisely so you aint upgrading suspension each year. b a fun trail rig fo sho
Old 02-27-2013, 09:32 PM   #4
underpowered
They call me......Scuba
i would have loved to do this to my 03 instead of selling it.
beat up rusted out k5
Old 02-28-2013, 11:22 AM   #5
boomhauer
boomhauer's Avatar
?...why do you have a ford front end for a chevy truck unless you are planning to change a lot of stuff.?
Old 02-28-2013, 01:06 PM   #6
BillysGruff
Goats on the Roof!
Same reason you have a linked HPD60 front.;)
Old 02-28-2013, 09:25 PM   #7
underpowered
have to change more stuff to use a chevy front end. IFS GM trucks are drivers drop from the factory, where as GM SFA trucks were all passenger drop. Ford axles are drivers drop, so easier to swap to match the stock front output side.
Old 02-28-2013, 01:00 PM   #8
BillysGruff
Goats on the Roof!
I want to shorten wheelbase at that time. Probably wouldnt be street legal then. Plan is to upgrade when it breaks, unfortunately not if, but when.
Old 02-28-2013, 05:28 PM   #9
BillysGruff
Goats on the Roof!
Thanks bud.
Old 04-26-2013, 05:28 PM   #10
I developed a crack on the driver knuckle in Harlan. Time to upgrade.
Sent from my Radar 4G using Board Express
Old 12-26-2014, 02:24 PM   #11
Have I seen this truck running around Anderson? Live on salem?
Old 12-29-2014, 09:27 AM   #12
BillysGruff
Goats on the Roof!
Yes Hopefully I wasnt doing anything stupid, lol.
Old 12-29-2014, 09:45 AM   #13
My mom lives next to the fire house and I work in Anderson. I see it all the time
Old 01-02-2015, 03:56 PM   #14
BillysGruff
Goats on the Roof!
So in order to make this work, I had to remove 5/16" of the splines from the back because the shaft has a non splined part. I used the drill press and a cylindrical grinding stone set at the proper height and went around till it was ground down fairly well. The first time I didnt take enough metal out and the assembly was moving back and forth. The second time I felt it slip over the non-splined part and the dust cover was in the right spot. I also ordered a 2011 Ram 2500 d-shaft from car-part for $85, which will be the base, since they have double cardon 1350 CV's with a flange that mates up well with the 208 flange. I may have to grind some down of the flange if its in 4-high. Looks like it might hit, but we'll see. I replaced the seal because it was leaking. I also put some caulking at the end of the splines just to make sure it doesnt leak anymore.
