For those that have a welder but no idea how to use it, how do you start? Where do you set the dials?
Any other info is always appreciated. :confused:
What kind of welder?
mig stick tig
I set it all over the place and tried it with different materials/rods. After I found what worked best that's how I (try to) set it.
Your wifes pimp!
Burn it till it holds!!!
![]() JK You need to practice and get used to the welder try different settings etc..
Here is the way mine were set last time I used them..The AirCo is a 230Amp Arc welder and the Lincoln is the 175Amp Mig..Both are 230volt machines..
Click on the pic for a larger view.. ![]() ![]() ![]()
Miamisburg,Ohio. Cell# 937-361-7267 90XJ Limited 4x4,4.0 Auto,NP242 Rustys 4.5" lift D30/D35,3.55 gears Denman Farmhand Tractor Tires 33x9.50x16 Work in progress http://smg.photobucket.com/albums/v2...0XJ%20Limited/ 1986 Chevy M1008 4x4 CUCV 5/4 Ton Truck 350ci,400turbo,D60 Front,14Bolt w/Detroit Rear 4.56 Gears, Desert Tan C.A.R.C. Paint. http://smg.photobucket.com/albums/v2...0M1008%20CUCV/ |
Well right now I have a 110 clark mig with flux core but no idea where to start.
Get you a bunch of 1/8-1/4 inch plate , clean and prep your area to be welded and start making some test pieces. Learn what each power/wire speed setting does to the "look" of the weld , learn how important gun angle and position is as well as direction.
Never weld with your battery connected :( in your vehicle and you may want to disconnect the computer too:o
Here is a good bb for welding questions and projects.
http://www.hobartwelders.com/weldtalk/index.php |
I know you've had problems (that was you tha thad to get a whole new harness, right?) but I have been welding on my & my buddys Jeeps for a while now w/o disconnecting anything. I just make sure I got a good ground very close to where I'm welding.
