www.buckeyejeepers.com
Suggestions on Drivetrain swap
Looking for suggestions on rebuild of my YJ. I picked up an HPD44 with Ox and D60 with Detroit from Hardluck friend for a good price. I was planning on regearing and running a flipped D300 on my YJ, but got to thinking today about not regearing and running an atlas. I will be running 37-38 tires AX-15 and 4.0
ORIGINAL PLAN – Regear both axles to 5.13 and flip D300 - Gears and install kits ($550) ,D300 ($150), D300 Flip Kit ($550), Gear Installation ($200), Clocking ring ($100) = Total of $1550 for a Crawl ratio of 51:1 TODAYS CONTEMPLATIONS! – Leave axles at 4.10 and buy atlas 3.8 or 4.3 - Cost $2000, Crawl of 60:1. It would only cost me and addition $450 and would save a ton of time and hassle with re-gearing and flipping the D300. I know overdrive would never ever be used but how underpowered would I be when not in low range? How bad do you think taking off from a stop would be? This is not a daily driver, but I do want it to be driveable on the road at 55-65 mph Let me know what you think Thanks Josh
1994 YJ, 4.0, 5 speed. *2006 Dodge 2500 Cummins, 4x4 Auto,Quad cab, LongBed, Tekonsha Prodigy(Tow Rig) Last edited by JeepHD; 10-08-2007 at 03:18 PM. |
I know I can't answer your question posted above, but you're also gonna have to account for a few other expenses into either scenario. (driveshafts, axle perches/mounts, rims, etc) Are you planning a gas tank relocation & wheelbase stretch also? This kind of project can add up real quickly.
Atlas is looking good. Are you running stock 30 and 35 axles now? If so you may want to go with stronger axles but if not run the atlas or the stak and have front and rear dig capability and sell the 300.
#4 | |
Just started checking on the Stak boxes. I will be comparing them with the atlas. Thanks for the input
go with the Tcase gearing. not only will it be easier, but stronger as well (depending on if you upgrade gears on the 300 or not.)
go with the stak, but im biased, and havent even run mine yet.
#6 | |
Thanks
#7 | |
Stak4x4 monstor boxes are also an option that I am looking into. Thanks for the response
