Old 05-18-2013, 09:13 PM   #1
GM IFS: What actually breaks?
New-to-me tow rig is an 02 Suburban 2500 with the big 8.1.
I've developed an incredible itch to crank up the torsion bars and stuff a set of 35s under it. Combination tow rig and light-offroad puppy-bus.
I know the IFS isn't exactly the hot ticket on the trails, but I assume the 2500 stuff is stronger than the half-ton, and this would only be rutted-dirt-road type of wheeling.
The worry is, this IS the tow rig. If/when it breaks, it has to be fixed to get it home.
So, what breaks, and how field-repairable is it? I assumed it was mostly CV half-shafts. Carry spares, swap em out, not so bad. Or, since they flange-mount to the diff, can't you just unbolt em and drive on in 2wd?
Doing a little research, I guess the streering linkage is fragile too. I can change out the steering on my XJ in about 15 minutes flat. Is the Burban stuff as easy?
Anything else? Any experiences?
Thanks all!
Old 05-19-2013, 08:42 AM   #2
Jonesy
Jonesy's Avatar
I know the biggest issue from being around the local diesel pulling trucks, is the tie rod ends and associated components. Under a hard load in 4wd the wheels will toe in several inches. There are several companies that offer upgraded components specifically for this issue. Other than that the only other upgrade the pullers do is a locker in the front. Not sure how that abuse correlates to the abuse we put on them off road.
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 05-19-2013, 09:20 AM   #3
I don't know the differences between a 1993 and 2002, but I put my 93 IFS through hell. I never broke a shaft. I did bend the tie rod, so I welded a small angle iron on it. If I can make it through rail bed in Harlan, I'd say you should be ok doing light off-road.
I had to put a 6" lift on mine to run 35's. I would assume your 3/4 ton sits higher than my 1/2 ton did.
I would upgrade the steering components and put the biggest tire you can fit under it without raising the torsion bars. My .02...
Old 05-19-2013, 09:56 AM   #4
X2 on the torsion bars. It will ride like hell if you crank them up.
LIKE IT OR LEAVE IT!!!
Old 05-19-2013, 09:56 AM   #5
underpowered
They call me......Scuba
most bend/break Tie rod ends. CV shafts can break, especially on cranked TB's.
If one breaks you can swap it out, or carry a spare stub shaft to get home in 2wd. just like your XJ, they use unit bearings and rely on the hub nut to hold it all together. if you pull the shaft, good chance your unit bearing will fail on the drive home.
otherwise, not many real trail breaks i have heard of with the IFS.
however, if you decide to crank it, be prepared to replace ball joints on a regular basis.
you can fit 33's with only a little crank, that is the route i would go, 35's won't much it much better off road than the 33's will.
beat up rusted out k5
Old 05-19-2013, 12:18 PM   #6
I don't know the differences between a 1993 and 2002, but I put my 93 IFS through hell. I never broke a shaft. I did bend the tie rod, so I welded a small angle iron on it. If I can make it through rail bed in Harlan, I'd say you should be ok doing light off-road...
That makes me feel better. I won't be doing anything like that.
I think I can fit a 33 as-is, with just a little rubbing. I know if you crank the bars all the way (like 3" lift) the ride goes to schidt. But I've read that an inch or two isn't too bad, and that might be all I need.
The upside is that if I crank it and hate it, I can always turn em back down.
I can fiddle with the lift, clearance and ride compromise. I just want to be ready for whatever trail breaks I might see.
Thanks for the insight guys!
Old 05-19-2013, 12:46 PM   #7
Speaking from the "I have a 2500HD on 33s" viewpoint, there is some tuck n trim to the bumpers and wheel well liners.
The weak stuff is:
Pitman and Idler arms
Tie rods
Unit bearings wear prematurely
I've avoided popping halfshafts, but I don't do boosted launches or offroad it, just pulling trailers back to remote lots
Old 05-20-2013, 08:44 AM   #8
hotrod
Diesel guy
hotrod's Avatar
I drag race my lb7 and I have tie rod sleeves and straight center link to keep from the "duramax wave" when leaving the line under boost. Same concept as before. If I were to offroad it, I'd want at least tie rod sleeves. You can get them anywhere, but I suggest merchant-automotive.com they are good people.
I also lowered mine 2/3 to get the cv shafts straight in the front hate on...
Not my truck, but an example.
2013 RZR S
