Old 11-25-2013, 12:55 PM   #1
tjeep
Longfield or Yukon super joints
What's better??? This is my first Toyota build and just wanting some input on the two... Ohh I'm new to the core family by the way my name is Craig Rhoden and I'm from Clarksville oh.
tjeep is offline   Reply With Quote
Old 11-25-2013, 01:36 PM   #2
Are you using a Toyota front axle? Reason I ask is did not think Yukon made a Birfield.
Old 11-25-2013, 01:47 PM   #3
Longfield or Nitro. Longfield is the best ImO
Old 11-25-2013, 02:28 PM   #4
rcv makes them all including trailgears dirty thirtys
Old 11-25-2013, 03:34 PM   #5
You can't go wrong with Dirty 30's. Just keep in mind the hub gears will be the next weak link, if a hub gear fails it can wipe out the splines on the hub end. Do it right and break down and get Chromoly inner & outer hub gears along with ARP Hub studs. Then the worries are over..... Unless you break the R&P... Lol...
Old 11-25-2013, 06:02 PM   #6
tjeep
Right now I'm running trail gear r&p Yukon Cromo shafts inner and outer with super joints trail gear crawler hubs and trail gear crawler hub flanges ohh and a Aussie locker....... I just didn't know if the birfield type joint was better that a u joint type.... The longfields look way stronger that the super joint IMO
Old 11-25-2013, 07:30 PM   #7
People have been beating on Longfields for years in Yotas... It would be the only stuff i would buy...
Old 11-26-2013, 09:15 AM   #8
..... Untilyou break the R&P... Lol...
Fixed it for you.
When the unjoints fail, they tend to take the knuckle ball with them. I have asset for spares only bc they came in mine when I bought them. Sucks to replace the knuckle ball. I've done it once on mine (hence the reason they are now my spares). Can't go wrong with longs.
Old 11-26-2013, 09:37 AM   #9
30 spline longs with driveflsnges and don't look back
