Old 01-07-2014, 11:32 AM   #1
Jonesy
Jonesy's Avatar
Fire extinguishers and mounts
All the talk at the meeting last night about safety and fire extinguishers got me thinking. I've had a couple but they were all the cheap walmart ones with plastic handles that only lasted one day bouncing around in the cab. So I really need to get a decent extinguisher and a good way to mount it.
Where is a good place to buy a decent quality extinguisher?
Looked around online and found a style mount I like. Threw something together this morning of my own. Just need to get a few of them burned out to try. Anyone have pics of how theirs is mounted?
ID:	7367   Click image for larger version
JT Jones
83 Toyota - beater
87 Toyota Truggy
Old 01-07-2014, 11:59 AM   #2
I have this style mount, which is just a standard "heavy duty" wall mount made of steel instead of plastic. Also invested a few dollars more for the steel handle extinguisher.
It is fastened to trans tunnel with sheetmetal screws. Been there for probably 10 years and never any issues.
Old 01-07-2014, 12:44 PM   #3
Ditto. Mounted in the same place too. Easily accessible from both sides. Never had any issues with mine either.
Old 01-07-2014, 06:08 PM   #4
jonesy,
I use a mount similar to the one you posted, with the addition of a spring loaded knob to hold the extinguisher in the mount and allow quick access with just a pull of the handle. My only complaint is that I would like them to be sided so that I can have the hook in the removable mount in the extinguisher pointed down on both the driver and passenger with the quick release pointed outward on both sides. I currently have the hook on the passenger side pointing up to put the quick release towards the outside of my rig.
I bought mine from liquid iron industries and hold them to my cage with hose clamps
jim
Old 01-07-2014, 06:12 PM   #5
I would recommend an all metal nozzle and minimum 5lb ABC extenquisher. There is a good write up on pirate...let me see if I can find it...
LIKE IT OR LEAVE IT!!!
Old 01-07-2014, 06:16 PM   #6
...found it...
http://www.pirate4x4.com/articles2/tech/2010-fire
Old 01-08-2014, 07:13 AM   #7
Pecker
Pecker's Avatar
I have a 10lb Ansul remote mount extinguisher with this same style of bracket mounted on the back of my cage, and the latch did not survive a roll. I'd vote for some type of quick release lock like this:
http://www.polyperformance.com/shop/...t-p-30822.html
Pecker is offline   Reply With Quote
