Old 01-08-2014, 11:13 AM   #1
bootlegger
4.0 Death
Engine went to 260 and blew a hose in my xj.Now she won't stay runnin. I'm assuming head gasket went.203k on the clock.Do I fix, replace or repower? Tight budget. I like little 4 cyl. diesels though......?
bootlegger is offline   Reply With Quote
Old 01-08-2014, 12:11 PM   #2
monkeystrong
SeƱor Monkey
monkeystrong's Avatar
Depends.. if its the gasket, then replace and keep on truck'n. if its the head itself, then I would start looking for options.
Old 01-08-2014, 12:36 PM   #3
Tight budgets and diesel conversions do not go together...
Fixing what you have is almost always cheaper. Even if you have to replace the whole engine, a bolt-in replacement is going to be faster, easier and cheaper.
Old 01-08-2014, 12:59 PM   #4
bootlegger
I guess I'll get the head off and go from there.I'm just thinking it's probably cracked.
BTW i was just reading that there's a 4.0 poweresd vehicle in the current Dakar rally.
Old 01-08-2014, 02:54 PM   #5
Put a tstat and new hose on and try it first... It's likely not runnin because of lack of coolant I noticed both if our 4.0 engines don't run right without coolant system sealed up and coolant in them ..., or u may have frozen it and junked it ... Is that possible?
Old 01-08-2014, 03:15 PM   #6
bootlegger
Something is freezing up.The crank pulley is smoking the belt.Accys are barely turning. I'm thinking water pump or power steering.
Old 01-08-2014, 05:10 PM   #7
There are two Jeeps in the Dakar and the top one was in 94th spot as of yesterday.
Old 01-10-2014, 05:32 PM   #8
bootlegger
After removing the belt , everything turns freely!!??
Good news is the oil looks fine and it drove back to the barn ok.I think i will change t stat, put a new hose and belt on ,fill up on critter killer and hope for the best.
