Old 05-18-2014, 12:23 PM   #1
Looking to buy
I'm looking to buy a Rzr Xp 900 here in the next month. I was going to get a XP 1000, but with all the goodies I wanted it was like 25k, so I'm going used with some goodies already on it.
I really don't that much about them so maybe you guys can tell me if they are worth it. What is too many miles or hours? Am I better off getting a low mile one and build it my self, or a higher mile one that has been built up already?
Out of these, which are the best deals.
#1 http://louisville.craigslist.org/sno/4433835015.html
#2 Gone
#3 http://cincinnati.craigslist.org/sno/4422038581.html
#4 http://lexington.craigslist.org/sno/4445588530.html
#5 Gone
#6 http://lexington.craigslist.org/sno/4454934158.html
Old 05-18-2014, 10:52 PM   #2
monkeystrong
SeƱor Monkey
monkeystrong's Avatar
I can't offer any info on which is a better deal, but I have been thinking about getting one also. I'd like to hear opinions on this too.
Old 05-19-2014, 10:18 AM   #3
ITLLFLI
I have a 2012 for sale with 300+ miles, roof with stereo and led lights, doors, harness', custom felt steering wheel and hub, bumpers, front and rear windows, cargo box, shoulder bag...etc
$14,000
Byron
513-470-848zero
ITLLFLI is offline   Reply With Quote
Old 05-19-2014, 11:22 AM   #4
Be careful where you buy one from. Being from Morehead, KY I can say that most folks there know how to use their stuff and use it often. If you buy one from Cincinnati...etc, it will most likely have been a toy rather than a workhorse.
I would shy away from a unit with modified stock components (chopped cages) and look at ones that have custom cages/bumpers with inspection. Doors, control arms and tires would also be on the desired upgrade list.
Old 05-19-2014, 12:14 PM   #5
fordman00
fordman00's Avatar
Me personally when I buy something used I want it with low miles and low hours.typically means it hasnt been rode hard and put up wet. But I know nothing about sxs.
Sent from my SCH-I535 using Tapatalk
Old 05-19-2014, 12:37 PM   #6
My low miles on my machines usually mean that they are finished! My old 800 is at the salvage yard now as the new owner finished it off a few weeks ago. The 900's are a great bang for the buck! Good luck with your searches.
Old 05-19-2014, 12:38 PM   #7
#2 or itlfli is my vote!
Old 05-19-2014, 12:41 PM   #8
Those were some HARD low miles. I suspect the 1000 is getting the same abuse...
Old 05-19-2014, 04:40 PM   #9
fordman00
fordman00's Avatar
Well obviously dont buy one from truggy.....lol
Old 05-19-2014, 08:33 PM   #10
kyrel69
Yes you do,,,,,, the parts form what ever he is saleing off
Old 05-19-2014, 10:10 PM   #11
If you buy a XP900 there are a couple must check things.
1 Make sure if its a 11 that it has the updated firewall heat shield.
2 Check the intake track from the inlets on the rear fenders down to and through the throttle bodies...look for the tell tale signs of being mudded. The air filter set-up on the XP's is super picky and it passes lots of dirt if it isn't perfectly assembled. I looked at two used 900's with dusted TB's before I bought the one I have now. The 900 is a great power plant but is notorious for having no tolerance for dirt of any kind.
3 Check the motor and trans mounts very closely.. on 11's especially , they are known for breaking clean off if wheeled even moderately in rocky terrain as the engine block hangs down very low between the frame rails.
4 Pay very close attention to reverse engagement and free play ..the 900 has a less than smooth tranny but the first thing that starts going bad is the puny reverse chain.
That's all I can think off the top of my head .
Edit....Get a power steering model...once you really start wheeling it and adding big tires and more power / performance parts you'll wish you had.
And get a cover for your truck... you wouldn't be driving it much once you get a SxS.
Old 05-20-2014, 04:49 PM   #12
solar1
10
Agreed. Low miles/hrs and but power steering model. I just put PS on my 800 S last week before a trip Tenn. Well worth it.
Old 05-21-2014, 08:19 AM   #13
CFD5
CFD5's Avatar
Another vote for itllfli's. I ride with him and it's not beat, mostly ridden on a local farm with no real big obstacles. Spends most of his time crawling at 5mph behind my jeep.
Old 05-21-2014, 02:31 PM   #14
If he still has it at the end of June I will check it out.
Old 05-21-2014, 04:44 PM   #15
Also pay particular attention when starting 11&12 models...they had a threaded idler shaft that's prone to coming loose and destroying the case . If you catch it early on you can save it but if not you're writing a $1,500 check.
Old 05-28-2014, 12:36 PM   #16
Here's one I thought was set up nice.
http://louisville.craigslist.org/sno/4466658177.html
Old 05-28-2014, 02:07 PM   #17
Already gone, sorry...
Old 05-28-2014, 05:52 PM   #18
Old 06-03-2014, 08:33 PM   #19
Thanks for all the help.
Jeff, you must have done some serious research before you bought one. I might have to get you to go with me before I buy one. Hopefully in the next few weeks I'll be ready to buy one.
Old 06-18-2014, 05:56 PM   #20
solar1
10
Also, stay away from the Polaris warranty. People seem to have better luck with the 3rd party warranty companies. I opted to not buy the warranty and luckily everything that I've had to work on wouldn't have been covered by warranty anyways. I.e. Wheel bearings, bushings, TRE, water pump seals, etc.
Old 06-19-2014, 09:21 PM   #21
https://www.facebook.com/photo.php?f...type=1&theater
2014 Polaris RZR 1000
164 miles
$18,500
Edit: Nevermind, you're finding new ones for that money...
Old 06-20-2014, 06:10 PM   #22
164 miles
$18,500
It depends on the add ons that's on it. Link doesn't work...
I decided to buy the 900 from Byron "ITLLFLI" I stopped by and checked it out. A 900 has plenty enough power for me. I'm picking up late next week.
Old 06-20-2014, 07:50 PM   #23
Think the ad is gone already... Somebody commented that there were new ones cheaper...
Congrats!
Old 06-23-2014, 09:06 AM   #24
Does anyone know how far you can compress the rear suspension on a RZR? The reason I ask is most enclosed trailers under 8' wide only have a door height of 66", but the specs on the RZR are 73". I have to know if it will compress that far with a ratchet strap.
Old 06-25-2014, 08:57 AM   #25
I just did a cage on an. 800 for a guy... Utilized the j strong roof with radio mounts... Dropped rear 2" (so tall guys can still fit) used 1.75 Dom... It's much stronger than stock setup
Also incorporated 30" light bar and a rear view mirror
