YJ Radiator Upgrade
I'm looking to upgrade the radiator in my my 91 YJ. The radiator that's in there now is original and is showing it's age. I'm going to replace with aluminum an electric fan set -up.
My questions is who makes a good quality radiator/e-fan kit for my YJ. |
Are you having cooling issues now? To be honest I'm not a big fan of either aluminum radiators or electric cooling fans. All other things being equal they do not offer better cooling ability.
Engine driven fans generally provide more air flow and are more reliable. I've seen lots of people lose electric cooling fans on the trail for various reasons. You can turn a e-fan off for deep water crossings but I have never personally seen a situation where it would really help. Using them for auxiliary/secondary fans is okay. Same thing goes for aluminum radiators. If the sizes are equivalent an aluminum version actually has less cooling ability. I think the perception from a lot of people is they think spending 2 to 5 times more on a part makes it better. Also they replace the half clogged and leaking old radiator with a bling aluminum and now the engine stays cool they think it is because the new radiator is great, not because the old one was junk. Maybe an aluminum radiator holds up better when being bounced around hard off-road, but I have never seen a radiator fail because of this. |
COMANCHE NUT
Opinions will vary of this subject. if you just need a rad, most any after market replacement unit will do the job. ( I prefer copper units) and if your factory fan system is working correctly its less expensive to just replace the rad. if you choose to go electric (I run Electric) it has a double cost setup. also make sure you have a alternator to support the electric fan a good fan (or fans) will require 20 to 40 amps so 90 amp alternator and above is recommended
but if you just replace the rad ,it will be much cheaper and will do just fine for stock setup.. as for brands I really don't think its matters that much.
I used an aluminum radiator for a v8 conversion on the 88 YJ at work. It has a 4.3 GM V6 in it. I used an electric fan because the stock fan didn't work out well. It has a 3" body lift. I have gone through 3 different fan controllers over the past ten years. I constantly keep an eye on the temp, just waiting on the controller to fail again. Eliminating the mechanical fan will bite you in the ass eventually. I only drive the Jeep when I have to plow snow. I would imagine a DD would make the controller die faster. A computer controlled fan would be totally different. A stock radiator and fan should do you fine. Add a manual electric fan if you need extra cooling if you're off-road. That's how my rig is set up.
While copper does transfer thermal heat better than aluminum the reason for the switch to aluminum is radiators actual cooling process happens from the core design rather than what material it is made of. Aluminum was chosen to save weight mainly and the design of all aluminum cores will out perform any copper core. You take the same exact size radiator of each and the aluminum will out perform the copper because of the core design and how it's bonded together.
In my CJ I'm using a Novak aluminum radiator and is well worth the money because of their warranty. I had a small leak develop and called them and they sent me a replacement one right away and said to use the same box and send the old one back. No questions asked all they wanted was a few pictures of the leak. Great service but was expensive. |
