Bedlift for Teryx4 - what are your thoughts
Thinking about doing a bedlift on my Teryx4. This is a fairly popular modification and usually done just for looks. It raises the rear bed up about 4" so the fender opening is equal between the front and back. It would be pretty easy to do and I think it gives it a better, more aggressive look.
Here are some pictures I stole off the internet. Let me know what you think. Stock ![]() After raising bed up 4" ![]() |
Definitely looks better lifted.
How much does it weigh? Enough to mess with the center of gravity?
To me it looks better unmodified . The small kick-up in the back of the rear door lines up and transfers the body line nicely into the bed in stock form...with the bed up high it just looks odd and mismatched to me.
I could see doing it if you where making clearance for bigger tires or more wheel travel but for looks , no thanks. It just makes loading the bed more difficult and pushes the COG up which doesn't sound like a good idea in a off road rig. |
You guys are not helping me any! Keep going back and forth on it but need to figure it out before building a bumper. Doubt the bed weighs more than 50 lbs so not worried about the CG, and the bed just holds a gear bag and cooler
Split the difference, raise it two inches.
I vote that you leave it alone Brad.
