Old 05-03-2016, 10:10 AM   #1
Toyota Front 3 link
So the time has come to link the front of my Rig, I have had alot of broken springs over alot of years and with the terrain that I tackle my body had been taken a beating along with my Rig
Old 05-03-2016, 01:15 PM   #2
Did alot of research for months on everything, didn't want to have regrets on anything that I did from start to finish on parts and design. Alot of thought went into everything considering the terrain and style wheeling that most of us do.
Old 05-03-2016, 05:15 PM   #3
There are alot of different places to shop for weld on tabs, Heims, and brackets of all sorts, I had to figure out if I was gonna custom make most of my link mounts or go with some good quality mounts that I can customize to make work for my needs, this turned out to be the best decision.
I did have to customize some of the brackets to work for my project, but let's face it, alot of rigs are PMC..Pretty much custom. I could not beat the price of the Heims for this price for as much as I shopped around. It made pretty quick, nice work out of most of this setup
Old 05-03-2016, 05:20 PM   #4
These lower link mounts worked out pretty good with only 1 of them needed modification
Old 05-04-2016, 04:35 PM   #5
Mocking up with PVC is alot of fun and alot of duct tape, Make sure you buy ALOT.
Old 05-04-2016, 04:42 PM   #6
After alot of investigation and horror stories I would advise beefing up the Frame where the panhard mount will be located, You cannot overdue this !! This is a major common fail on a front 3 link, I used 1/4 plate over the frame on the side and in the bottom and plug welded, make sure you spread it way beyond the stress point.
Old 05-04-2016, 08:46 PM   #7
simpletoy
Not sure if it's the angle of the picture or not but you may want to consider the panhard mount on the axle and shock interference? May just be the angle though not sure
Old 05-04-2016, 09:09 PM
Old 05-04-2016, 10:24 PM   #9
Thanks for answering for me Mark, yes things are close but ok, will hopefully have truck on RTI ramp tomorrow to max out suspension to look things over, Mark, Kevin, and I played with it last weekend on the lift and it appears everything will be ok but prefer to twist everything up as much as possible. With suspension fully compressed steering is bout 1/8 of a inch away from the oil pan and my top link bar is bout 1/2 away from clutch slave cylinder. Will post up more pics and info as I can.
ID:	8850   Click image for larger version
Old 05-04-2016, 10:25 PM   #10
Different angle pic
Old 05-04-2016, 10:38 PM   #11
16 inch ORI's was decided as my choice after alot and i mean alot of research on what to run for my wheeling style and terrain that we tackle, they are very easy to dial in, require no bumps tops, limit straps, don't unload so you don't need a suck down winch and are very predictable and by a turn of a screw with a smile you can set it how you like it. So far I haven't adjusted anything and it rides better than any vehicle that I own.
Old 05-05-2016, 08:02 AM   #12
The shock hoops were a tight fit. The driver side the master cylinder was in the way, and passenger side the propane and carb was in the way. It all fit, barely... I'm glad I will have more room on my rig. I'm so ready to get started on mine.
Where's that pic of full droop?
Old 05-05-2016, 09:30 AM   #13
Hotwheels
Hotwheels's Avatar
Looks good!
Old 05-05-2016, 01:27 PM   #14
simpletoy
Good deal. I did a 3 link on a guys Toyota and tie rod and panhard were so close t was ridiculous. Hope he never bends his tie rod. Let's see some full flex pictures!
Old 05-05-2016, 05:47 PM   #15
If all goes well I will post up some later this evening, here is a couple pics, 1 is before charged and after
ID:	8858   Click image for larger version
Old 05-06-2016, 07:56 AM   #16
Had too many things pop up yesterday so I was unable to check for clearance issues on the RTI ramp, hopefully today will be a better day.
Old 05-06-2016, 09:06 AM   #17
simpletoy
Looks like you did a stellar job man. Any plans for a ride in the near future? Couple of us may be headed to Harlan in June if at all interested
Old 05-06-2016, 10:56 AM   #18
Well here is what I have do far, I have 2 inches of shock left to extend but after falling of the ramp twice I decided to give up, I'm glad I did, ORI is starting to dig into frame and hit steering shaft, will have to do some clearancing this weekend
ID:	8862   Click image for larger version
ID:	8861   Click image for larger version
Old 05-06-2016, 11:25 AM   #19
Same story with passenger side had to stop going up ramp or risk damage to ORI due to contact with the frame.
ID:	8864   Click image for larger version
Old 05-06-2016, 01:37 PM   #20
Outstanding! Great work.
Old 05-06-2016, 01:49 PM   #21
A few others and I are headed down Thursday May 26th for Southern Shine weekend..come on down
Old 05-06-2016, 02:03 PM   #22
simpletoy
Would love to but can't make that weekend. Already have plans to be on the lake. I appreciate it though
