Old 05-09-2016, 08:19 AM   #1
Pitman Arm Modification
Looks like I have a clearancing issue when I compress driverside front wheel, my pitman arm is coming in contact with my tie rod bar, never dreamed the axle would move that much, looks like if I bend the pitman arm up maybe around 5/8 - 3/4 of a inch I will be fine, I have heated and bent alot of different things in my time, I'm hoping it's ok to heat and bend this, anybody out there see anything wrong with this ?
Old 05-09-2016, 10:12 AM   #2
Other than what you already know, heating it makes it weaker. I've done it before, but I didn't run it long before I went to full hydro. It was a beefy piece too.
Old 05-09-2016, 12:27 PM   #3
I've always heard ...cast=no... forged =yes.
Old 05-09-2016, 02:58 PM
Old 05-09-2016, 06:19 PM   #5
Problem I'm having is the flat 1 won't work, it will hit the frame unless i bend it, hey do have 1 that is in between but I'm worried it may hit the steering also, it's $110.00 for the 1 in between, it's $85 for the flat 1, not sure if the in between 1 wikl work or not.
Old 05-09-2016, 06:20 PM   #6
Gonna put it on the ramp again and see what I can do
