- Moderator - |
Suspension Rebuild
I am beginning the suspension rebuild on my Jeep CJ-7.
Current setup is leaf in front and TJ Coil springs in back. Race Runner 14" shocks at corners. New setup Same 3 link hybrid in back. 4 link new setup with truss in front. ORI 16" shock/struts on the corners. http://www.cincyoffroad.com/gallery/...p?c=11&userid=
Keep them on all 4's Last edited by jeepmanjeff; 09-16-2016 at 11:34 AM. Reason: added gallery link |
- Moderator - |
I have to say our picture tools suck! Sorry I tried to flip some of the pics and it just does work. If your neck hurts my apologies
Keep them on all 4's |
- Moderator - |
Made steady progress this weekend. 4 linkis complete! I have 35.25" lower links and 25" upper. All triangulated to the max I can allow. No hinderance anywhere with full flex. Next up is hydro lines, brake Lines and exhaust relocate. Once the ORI get here I will be rocking again
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
- Moderator - |
More progress. ORI shocks arrive today. Driveshafts installed and new center brake drop in. Will get new hydro lines tomorrow for steering and install shocks as well. This Sunday I pick up my 39.5 boggers I am trading my 44 for even Steven.
- Moderator - |
Wish but with work travel I am for sure not going to be done. This working on weekends is cramping my time frame.
#13 |
- Moderator - |
Pics from the side as requested. I got the new radiator completed, left brake line ran, d-ring welded on for chains and struts turned to gain access for the charging ports.
#15 |
- Moderator - |
More progress got the radiator bled and brakes. Made a new light bar for 40"LED light bar to be acquired later. Got a coat of paint on her as well. Lots of sanding off the old red that I hated!
#16 |
- Moderator - |
Getting closer. I had to move the front axle strut mounts 2 times to
Get the clearance I needed for the tires. But it is done. Need to rerun the front brakes and paint again. Charge shocks as well then test. ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
#22 |
- Moderator - |
Suspension performance
Well I have to say this was a great investment. Got a lot of complaints I was going to fast down the trails
![]() https://www.facebook.com/photo.php?f...type=3&theater
