Old 11-15-2017, 04:14 PM   #1
Truggy Build 3.0
Building a truggy from a 2004 Dodge Ram 1500.
Picked this up from Cincy Thouroubred Harley Davidson. Was a parts hauler till it got side swiped on the highway.
Parts that I will be keeping on the truck are part of the front end, most of the frame, motor, trans and cab. Sold most of what I am not using to help the funds. Still wondering if the cab should go or not.
Here is what I am currently thinking of using for this build.
97 Dodge dually Dana 60 front 4.10 gears welded (looking to upgrade shafts)
2004 GMC 2500 14 bolt 10.5 ring gear rear. Posi that I need to lock in some fashion.
Full hydro from PSC ? or homebrew
NP241 Rubicon t-case 4 to 1
1350 driveshafts. Have 2 fronts from JK builds that I will build up
42" Irok Stickies with Stazworks dual beadlocks (thanks Scott A)
Warn 8274 that I have had for quite a while
116" wheelbase possibly and shooting for under 5000 lbs.
4 link front with track bar, 3 link rear with track bar, 4" JK springs, looking into heim joint brands
Old 11-15-2017, 04:21 PM   #2
Stripped the 1/2 ton bits away from the chassis. Lightening mode now.
Old 11-15-2017, 04:22 PM
Old 11-16-2017, 01:21 PM   #4
Moved to the welding / fab area. Still shaving weight.
ID:	9649   Click image for larger version
Old 11-17-2017, 12:10 PM   #5
NICE! Back on the trails soon?
Old 11-17-2017, 12:48 PM   #6
monkeystrong
SeƱor Monkey
monkeystrong's Avatar
Too cool!
Old 11-18-2017, 11:32 AM   #7
This thing will be a beast
Old 11-18-2017, 08:37 PM   #8
Better take it easy on that 241. I've broken the case around the front output 4 times on mine. Decided to take a different route on the s10.
Old 11-20-2017, 10:29 AM   #9
Glad to hear you speak of the s10 again....any updates?
Old 11-27-2017, 08:03 AM   #10
Was the rear a fixed yoke output? I have never seen a 241OR destroyed on the trail behind big hp.
Old 11-20-2017, 07:19 PM   #11
I'll be ordering tube soon and getting busy on it. Been finishing up some stuff so i can get it done. Had to beef up the rzr since the truck will be down for a while. end hijack
Old 11-22-2017, 08:02 AM   #12
Shaving a 14 bolt currently, adding a spool, new brake hardware and truss.
Old 11-22-2017, 06:34 PM   #13
hmmm...want to do another one? Call me...5132507941!
Old 11-27-2017, 08:02 AM   #14
Not really! It is not a major shave. Ring gear is still stock.
Old 11-27-2017, 08:39 AM   #15
I never had a problem with the rear, it was always the front output that cracked the case. I could still drive it after the front broke. Two of the four breaks were front drive shaft related. I broke one going up little Jagger , and the last one I'm not sure why it broke. I was on the waterfall at Harlan. These are 241 C, I know the one you're referring to is stronger but is the case stronger in that area. My transfer case I can get for $85 at any junk yards, but yours is a lot more expensive and harder to find.
Old 11-28-2017, 08:05 AM   #16
The front cover area is different in design and just the front case cover can be bought for 110.00 separately. Crossing my fingers.
Old 11-28-2017, 09:30 AM   #17
hey Kevin. when you order tubing let me know. I will order some as well with you so we can get a better discount. I get a Military discount at Ackerman as well.
Old 11-29-2017, 02:55 PM   #18
I have a Rubicon case that came out of my 05 LJ. Both halves of the case around the front output are cracked due to my front driveshaft ejecting at highway speed. The rest of its fine. I kept it for spare parts but sold the LJ. You are welcome to it if you think there is anything you can use off of it.
Old 11-30-2017, 06:33 AM   #19
That's a deal! It will at least be good for parts. Will you be at the next meeting?
Old 11-30-2017, 02:32 PM   #20
(FYI, no December meeting, next isn't until January 11th...)
Old 11-30-2017, 05:18 PM   #21
Probably not. Raising 7 kids I don't have much time for club stuff. I live in Union. Give me a call if you want to come get it. (859)786-9785
Old 04-24-2018, 01:26 AM   #22
Gonna make Rush this weekend?
Old 08-15-2018, 08:14 AM   #23
Maybe in October.
A few more pics of the progress.
ID:	9976   Click image for larger version
ID:	9978   Click image for larger version
Old 08-15-2018, 10:16 AM   #24
Go to Harlan with us in october
Old 08-15-2018, 10:44 AM   #25
As long as it is not during a busy event such as the shine crawl I may be in. I want to cover some ground.
