Old 09-04-2018, 08:09 PM   #1
Haspin Saturday September 22nd
Anyone interested in a Haspin Trip on Saturday September 22nd ?
Post up if interested..
I will be going in my Rig
My boy will be going in his 1st Gen Yota
Jeff Pendergrass in 1 of his rigs of his choice
My boys friends in a couple Jeep Cherokees
Old 09-04-2018, 08:54 PM   #2
I would, but the jeep will be completely torn apart and the front end of the fram will be chopped off.
Old 09-05-2018, 03:38 PM   #3
Hm, I'm a maybe. I have Rush Repairs to do, and my dad's birthday is in there sometime. Will update...
Old 09-05-2018, 09:11 PM   #4
Birthday is cleared. Steering linkage tonight/tomorrow. R&P this weekend hopefully. So the 22nd is looking pretty good.
Open invite, or trying to keep a handle on the group size?
Old 09-05-2018, 10:11 PM   #5
Open invite..
Fun for all,
If group is too big we can split it up,
We can put some beginners with experienced
Put some less capable with capable so no 1 is uneasy
Get some rounded up, you seem pretty good about that.
Old 09-05-2018, 10:27 PM   #6
Ha, sometimes TOO good!
Old 09-19-2018, 01:59 PM   #7
I am planning on being there. Have a few very minor repairs to do still.
Old 09-20-2018, 11:16 AM   #8
Unfortunately, I am out. I still don't have my front axle back, and now the Burban is down too.
I hope to get everything sorted out in time for the CORE Tour, but even that is a maybe at this point...
Old 09-20-2018, 11:17 AM   #9
What happened to the burb?
Old 09-20-2018, 11:25 AM   #10
All four brakes are dragging. Shop says the fluid has been contaminated at some point, and it attacked all the rubber in the system. Everything needs to be replaced and flushed $4000 for him to do it.
I can get calipers, hoses and a master for less than $500, but a new ABS module is like $1200. So, maybe I do everything else and hope, or try to find a used one...
Old 09-20-2018, 01:18 PM   #11
Ky Mudhunter
Ky Mudhunter's Avatar
If it is just from contamination, you shouldn't need the entire ABS module. Just the valve body section. Not sure what year your Burb is but most of the valve modulators on Rockauto are under $500.
Old 09-20-2018, 02:47 PM   #12
We found one at Reitmans for $150, so I'll probably go that way... Thanks for the tip though.
Old 09-23-2018, 09:08 PM   #13
Haspin Trip went very well,
Tony V managed to relocate his axle due to a broke center pin on the Drivers front very early into the Run, a little while later in the day Tony and a few repaired and he was able to get his rig back on the trail.
Other than that no damage as far as I know to anyone's rig.
The creek bed leading to the backbone with the waterfall ledges have been severely warn in from traffic and mother nature, it swallowed my 40's going down and was fun driving back up. Jeff Pendergrass on Tons and 42's took a bit to finally be able to to get up it. Before to long it's gonna require 40 + tires and skinny pedal with hopes and dreams to drive up it. We made our way around to different areas which seemed like at times ended us up in Lostville but was a good time no matter which way we turned. Thanks to all that showed up to wheel.
