Old 01-02-2008, 08:27 AM   #1
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Necessary to cut off runflats?
Is it really necessary to cut the runflats off of the hummer beadlocks to run 38x12.50x16.5s? I am just being lazy and it looks like it will be a pain to cut them off.
I have heard of them rubbing and tearing up the inside of tire at low PSI.
Thanks
Josh
1994 YJ, 4.0, 5 speed.
Old 01-02-2008, 10:42 AM   #2
Less weight if cut off and they can get in the way of tire flex. I am not sure if they will work with both a 6 or an 8 ply tire though. They are magnesium so don't do anything that will make them burn!
Old 01-02-2008, 10:55 AM   #3
JeepHD
JeepHD's Avatar
I mounted one of the TSLs on a rim last night just to check it out. Seemed to mount up nicely. I just don't really feel like cutting the runflat portion off, but I probably should. Also I don't have a band saw so I will have to do it with a sawzall and it doesn't look like it will be very easy.
Thanks
Old 01-02-2008, 02:19 PM   #4
weight... ha, thats funny truggy... the things weigh next to nothing...
but, yes i would cut them off running anything less that a 40" tire. they are quite brittle and crack if hit just right. when the crack, they create sharp edges that will cut a tire.
when i ran my 39.5" boggers, i kept about 5 psi in them and every once in a while on a hard hit, i would feel it hit. Don't think i ever cracked one, but never had them apart to check either, so who knows.
I am cutting my current ones, and i'm gonna be running 44's. Bette safe than sorry i guess. They will cut fairly easy with a sawzall blade. Just get you some super long Milwaukee "torch blades" and it will roll thru it pretty easy. you will have to use a grinder as well to get them down close.
here is a shot of some shaved runflats for inspiration...
Old 01-02-2008, 02:49 PM   #5
I am a fanatic on weight savings! But what about the 6 or 8 ply tire. Will the hummer runflat insert accommodate either?
Old 01-02-2008, 04:20 PM   #6
JeepHD
JeepHD's Avatar
I was pretty sure I needed to cut them, just didn't want to hassle with it. Guess I will get some long sawzall blades and go at it. My TSLs are 6 ply and the one I mounted went on fine.
Old 01-04-2008, 12:33 AM   #7
JeepHD
JeepHD's Avatar
Weights for your information:
35 lbs - H1 rim only(no beadlock or runflat)
47 lbs - H1 rim with complete runflat
41 lbs - H1 rim with beadlock (runflat cut off)
12 lbs - Runflat
6 lbs - Beadlock only (runflat portion cut off)
These are in no way exact numbers but close. I put them on a household scale that a person would weigh themselves on.
Old 01-04-2008, 07:02 AM   #8
Yeah my 42" swamper tsl's and h1 rims were 148lbs!
The new setup will be almost 200lbs!
Old 01-04-2008, 08:18 AM   #9
JeepHD
JeepHD's Avatar
What else did you do to cut that much weight? Mine should be around 114 lbs.
Someday I would'nt mind upgrading to aluminum rims with stauns, but this is a cheap option for now.
Old 01-04-2008, 09:00 AM   #10
I have been in situations where I have bent my steel rims very very badly and we were able to hammer them back into place. Aluminum rims would have cracked and I would have been in trouble. Just thought I would put the idea into your head.
Old 01-08-2008, 12:50 AM   #11
JeepHD
JeepHD's Avatar
Progression of cutting Runflats using Holesaw and sawsall method
Name:  H1 ring prog.JPG
Name:  H1 ring prog2.JPG
Finished Product
Name:  H1 Beadlock finished.JPG
