Frame Alignment...89 Suburban
My wife drove my 4x4 89 suburban today and I followed her. The truck looks like it tracks straight but the left front wheel seems to be sticking out further than the rear. I could not notice this on the passenger side?
Any good frame shops out there that could check this and work on it if it would need tweeked? |
Jeepless
Generally all vehicles WMS is wider in the front than the rear. If the vehicle is tracking straight and your not eating ball joints, or other suspension bushings. I wouldn't bother looking at it.
Is it lifted or stock?
stock
The front axle on this truck will be about 3" wider (1.5" on each) than the rear axle...may not sound like much but it is quite noticable. If you were following it in another car I wouldn't be surprised if you could just notice the driver's side since you couldn't really see the passenger side that good.
Follow it on the hiway, probably tracks
on both sides, as stated above but, it is easy enuf to take a tape measure and get a buddy, crawl under it and measure it in a X fashion frames has reference holes in them look around you will find something to measure from spring center pin, lower ball joint, ECT...
