Old 01-20-2008, 12:58 PM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
4WD acting up
have an 86 Bronco
where would be a good place in Cincinnati to take it to get looked at?
I want someone to just diagnose the trouble then I'll fix it if I can
Update
I lifted the truck off the ground
the front drive shaft is turning and the left Axel
The right Axel is not turning
do I need to replase the front end
hubs unlocked no grinding
locked hubs and get a lot of grinding
Old 01-20-2008, 01:41 PM   #2
What is it doing? we will do the best we can
Old 01-20-2008, 01:44 PM   #3
SixFtUnd
Danny Beach
SixFtUnd's Avatar
well
it was grinding not wanting to go into 4wd
thought the transfer case was shot
I went to the jusnk yard to get another one but first I went out behide there where I drive sometimes and it worked just fine not one problem
then yesterday I went out and it just didn't seem to be working no grinding or nothing don't know how to explain realy just didn't seem right
Old 01-20-2008, 01:48 PM   #4
My guess is linkage bent or binding up. Also check your engine mounts and tranny mounts to make sure they are good. My friend had a 84 F-250 and no matter what he did the bolts holding the tranny and transfer case together would always back out.
Old 01-20-2008, 01:53 PM   #5
SixFtUnd
Danny Beach
SixFtUnd's Avatar
thanks
I just had my tires balanced and alignment done on it at Tire Discounters and asked them to look at the linkage they said it looked fine would you trust them at all?
Old 01-20-2008, 02:00 PM   #6
I would but at the same time the guy looking at it might not have any idea what the linkage is supposed to look like.
