www.buckeyejeepers.com
Swap 92-95 4.0 in a 89 Cherokee
I have a friend with a 1989 cherokee with a bad 4.0. I have a good 4.0 out of a 92-95 YJ. Will this motor swap in easily to the Cherokee. The only problems I could think of is if the Renix Fuel injection intake and exhaust manifold bolt up to the block without any problems? Thought there might be some changes in that over the years.
Thanks Josh
If you have both complete motors it should be a fairly easy swap. You may need to put the intake and a few other goodies from one on the other but no big deal.
#3 | |
Thanks
TRy to get ahold of JFiscus. Jason has swapped an HO in to a Renix body, I think
#5 | |
Everything you need to know should be in here: http://www.terrainstompers.com/forum/viewtopic.php?t=14 The only things not covered are AX15/BA15 trannys - if you have a standard shift there are a few other steps/variations involved sometimes. What tranny ya using & what year is it? If you want to call between 6-9pm weekdays I can answer some questions on the phone 513-967-7091 or PM me here. |
#6 | |
