Old 03-09-2008, 03:07 PM   #1
RD TRCTR
Toyota Help
I've got a 1985 'Yota with the 22REC engine. I am currently getting the MIL (code 12) for the knock sensor. The only issue is that the engine does not have a knock sensor. I've had this truck for a while now and all of a sudden this code shows up. I did just recently replace the TPS. If any one can provide some help it'd be greatly appreciated.
Old 03-09-2008, 08:04 PM   #2
4RunnerAdam
4RunnerAdam's Avatar
You mean the knock sensor has been removed?
It should be near the oil filter. Has a green wire going to it.
Old 03-10-2008, 12:11 PM   #3
RD TRCTR
'Yota help
Is the truck supposed to have a knock sensor? It ran just fine with no check engine light until here recently. I guess I'm confused as to why the CEL wasn't on and then all of a sudden it came on. Thanks for the help.
Old 03-10-2008, 05:40 PM   #4
4RunnerAdam
Yup, should have a knock sensor. Why it worked without one I don't know. Parts store are showing a new knock sensor for $155 I'd find a used one.
Old 03-10-2008, 08:54 PM   #5
krawlin85toy
krawlin85toy's Avatar
Images: 76
Had the same problem at 1 time,could be a knock sensor,tps,and or dist. my problem was the wire to the knock sensor has to be shielded after I replaced the end and have trouble free since. 4tears knock on wood!
Old 03-13-2008, 06:48 PM   #6
RD TRCTR
'Yota Help
I took your guys advice and finally looked for the knock sensor today. I couldn't find it. I looked all over the intake side of the engine. I then called a dealer and gave them the VIN. According to them, it should have a knock sensor and it's located on the exhaust side of the engine (?). I figured that since I had replaced the TPS, that maybe I didn't set it right. So, I followed the directions in the repair manual and online. Took the truck for a drive, CEL is back on for code 12, knock sensor. Do I need to pull the plenum to find the knock sensor? I did replace the injectors in January. I also found the connector that goes to the knock sensor and it has a decent amount of grime in it leading me to think that it has never been hooked up. The truck was built in November of '84. Thanks a lot for your advice.
