Old 04-22-2008, 09:38 PM   #1
Traxxas issues.
I have had a Nitro Rustler for roughly 10 years. It does not come out often enough. In 10 years it has had maybe a gallon and a half run through it. Lately I have been using it more and more.
On full throttle it bogs down. If it stalls, it is very difficult to start. This only happens when it warms up. I rarely run the body so it shouldnt be overheating. And the fuel is newer.
Has the electric start with the auto glowplug. And I think it has the .15 engine. Any ideas?
Old 04-22-2008, 10:08 PM   #2
Do you put oil in the cylinder when it sits? Glow plugs bad, fuel bad, o-ring on carb split, tank has a crack or fuel hose letting air in, check temp of head to be sure carb is not clogged. They can be finiky!
Old 04-22-2008, 10:19 PM   #3
Did the same with brand new fuel, and has a new glow plug. Fuel hoses are all new. Usually I put the oil in. Every once in a while I forget. What about carb adjustments? I have heard if one thing is out they run bad. I have also heard carb adjustment is very difficult.
Old 04-22-2008, 11:07 PM   #4
o-ring and tank okay? idle screw easy. mixture screw tricky. Need a temp guage to set it. Wonder if compression is an issue. Same brand of fuel?
Old 04-22-2008, 11:44 PM   #5
OH-cj5
I had a rustler years ago if you hit the gas and it bogs but poors a ton of smoke out you need to lean it out and just the opposite if you hit the gas and it bogs but no smoke richin it up
OH-cj5 is offline   Reply With Quote
Old 04-23-2008, 12:19 AM   #6
No different bramd of fuel. Ran it again and paid close attention to it. It blows lots of smoke. Any idea how to lean it out?
