hp 30
heard good things and bad. really all i need to know is it a better 30 than the stock one in my tj. bolts directly in and everything. heard that the hp 30 and a super 30 kit makes it almost indistructable.
#2 | |
Your wifes pimp!
Well, A HP D30 is stronger and a Super 30 kit can make it 30 spline if you change carrier/locker. stock is 27 spline. Your in luck I have a HP D30 housing sitting here for you! ![]()
how much for the housing adn what all is included. and what size tire would this thing finished be able to handle locked and 30 splined
Your wifes pimp!
sent you a PM. I have seen guys run 37"s or 38"s depends on how heavy a foot you have. I ran 36"s for a while with out a problem.
35 bfg krawlers here with a stock hp 30, if i had a super 30 kit, i wouldn't be afraid of running 37's.....
38,s now thats pushing it just my 2 cents later E.
01 TJ |
anything over a 35" and you'll be changing balljoints pretty regularly. 35's and smaller, and you'll be fine with that axle.
